Mk5 electric adjust headlight & switch..................SOLD
Postby MinorMatt » Fri Jun 15, 2012 10:26 pm
Mk5 headlights with the electric motors in the back for height adjustment.
Complete with switch/controller.
£50 for the pair
If you let me know before midday tomorrow (16th June) I can take them to North Weald
Re: Mk5 electric adjust headlight & switch
Postby shadyocuk » Sun Jun 17, 2012 9:36 pm
If these are a straight swap for normal lights and are glass I will have them.
shadyocuk
Postby MinorMatt » Mon Jun 18, 2012 12:16 pm
They are plastic lenses, but very good ones, and they are a straight swap IF you have the wiring loom (I think its likely that you would if your van has the 4 spaces for switches on the grey part of the dash below the vent on the drivers side)
Postby dirtydog » Tue Jun 19, 2012 10:57 pm
You still got these Matt?
I reckon I've got the high spec loom (wiring was there for leccy windows and mirrors and have the blanks in the dash) what do the plugs look like for the headlights and switch?
dirtydog
Postby MinorMatt » Wed Jun 20, 2012 7:30 pm
I can't remember what the headlight ones look like (and they are in my workshop ~60 miles away)
The switch has a square socket about 1/2" square with 4 straight connections which are in a 2 x 2 configuration and all face the same direction
Postby dirtydog » Thu Jun 21, 2012 7:59 am
Plug on the left in this picture I presume from your description
Also found a found a 3 pin plug behind each headlight, so good to go I reckon!
I'll have them off you, PayPal or cash preferred matt?
dirtydog
Postby MinorMatt » Thu Jun 21, 2012 6:22 pm
PM Sent
Postby dirtydog » Tue Jun 26, 2012 10:21 pm
Cheers for dropping the lights off tonight matt.
The bulb in the switch had blown, do I get a discount for that? :wink: :wink:
dirtydog
Re: Mk5 electric adjust headlight & switch..................
Postby MinorMatt » Thu Jun 28, 2012 7:33 pm
If your desperate I will send you another! :lol:
