Expanding foam filler, is it OK to use in a Campervan
Postby paulrichardson » Sun Jun 24, 2012 6:16 pm
Hi Guys,
I have insulated under my ply floor, but because I re-used the floor that was already fitted I have some gaps in corners etc.
I bought a can of Expanding foam "Big Gap" filler.
Just wanted to check that I am OK to use this in my van.
It's not going to "attack" my paintwork or anything?
Looking forward to hearing from you.
Regards,
Paul.
paulrichardson
Re: Expanding foam filler, is it OK to use in a Campervan
Postby robbie.cee » Tue Jun 26, 2012 8:33 pm
it may well hold moisture against hard to reach areas of panels and is super toxic when burning so beware!
awesome stuff tho if not messy!
Had
X-Reg Mk5 150ps 3.0 ESSEX V6
MAKE IT FIT
robbie.cee
Postby Highlander250469 » Tue Jun 26, 2012 9:14 pm
robbie.cee wrote:it may well hold moisture against hard to reach areas of panels
I've just removed a whole load of his from the headlining of my County, it a pure B******* to get off!
Definitely holds the moisture in, a lot of mine was quite badly rusted behind it
Highlander250469
Postby TIMO » Tue Jun 26, 2012 9:33 pm
i would say no too.
BBC = British Broadcasting Conspiracy
http://www.youtube.com/watch?v=nj82wxnO ... r_embedded
TIMO
Postby duvet » Tue Jun 26, 2012 10:28 pm
but it fun squirting into GATSOs
ex-network rail 2007 mk7 100 LWB 350 8 seat.
buses stop at bus stations, trains stop at train stations....... on my desk i've got a workstation
duvet
Postby robbie.cee » Tue Jun 26, 2012 10:29 pm
duvet wrote:but it fun squirting into GATSOs
8) 8) 8) 8)
Had
MAKE IT FIT
robbie.cee
Postby TIMO » Tue Jun 26, 2012 10:38 pm
Lol for sure,, you ever heard of necklacing ?
TIMO
Postby robbie.cee » Tue Jun 26, 2012 10:42 pm
??? go on..... :lol:
Had
MAKE IT FIT
robbie.cee
Postby TIMO » Tue Jun 26, 2012 10:54 pm
You asked :mrgreen:
http://www.youtube.com/watch?v=iprAsCibZtM
Also,, most of these have been necklaced,,, thought id show you how to do it first with the first vid :wink:
http://www.youtube.com/watch?v=i-iUpmynIBE
TIMO
Postby paulrichardson » Wed Jun 27, 2012 5:48 pm
Hi Guys,
Thanks for all your comments (although I'm not sure how we got on to setting fire to Speed Cameras).
I think the concensus is - I won't use the Expanding Foam spray stuff.
My new question is "What can I use instead".
I think the gaps are too big for Sikaflex.
What about "polyfiller" type stuff?
Regards,
Paul
paulrichardson
Postby robbie.cee » Wed Jun 27, 2012 6:06 pm
needs to be sealed water tight then maybee insulation or vapour barrier then insulation.
foil type bubblewrap is good stuff
Had
MAKE IT FIT
robbie.cee
Postby ake » Fri Jun 29, 2012 3:03 pm
I would also suggest the foil bubble wrap, it can be pushed into tight spaces
Postby transitandy » Fri Jun 29, 2012 10:34 pm
Quilted foil is the best stuff :)
Postby robbie.cee » Fri Jun 29, 2012 10:40 pm
admittedly i just used recycled glass loft rolls stuffed behind the ply walls. kept us toasty at north weald, had to keep rear door ajar even with roof vent(fkin noisy thing- if fit one, jam it up at night or it sounds like an animal humping on your roof :evil:)
i just used a minibus rear head-liner for the roof , does the job but poss not in midst of winter!
Had
MAKE IT FIT
robbie.cee
Postby transitandy » Fri Jun 29, 2012 10:45 pm
robbie.cee wrote:admittedly i just used recycled glass loft rolls stuffed behind the ply walls. kept us toasty at north weald,
Cheapest option and maybe the best :wink:
