taz666 wrote:here is a list of all the spec numbers for gearbox oils from ford etis
MK5 MT75 Transmission fluid ESD‐M2C186‐A
MK6 MT75 RWD Manual transmission fluid WSD-M2C200-C-----75W-90
MK6 VXT75 FWD Manual transmission fluid WSD-M2C200-C-----75W-90
MK6 MT82 RWD Manual transmission fluid WSD-M2C200-C-----75W-90
MK7 MT75 RWD Manual transmission fluid WSD-M2C200-C-----75W-90
MK7 VXT75 FWD Manual transmission fluid WSD-M2C200-C-----75W-90
MK7 MT82 RWD Manual transmission fluid WSD-M2C200-C-----75W-90
MK7 MT82 4x4 Manual transmission fluid WSD-M2C200-C-----75W-90
MK7 VM6 FWD 6 speed WSS-M2C200-D2-----75W FE
hope this helps every one
Altransit wrote:taz666 wrote:here is a list of all the spec numbers for gearbox oils from ford etis
MinorMatt wrote:A good quality 75w90 oil,
Easily avaliable here from any motor parts store.
I use comma oil because its what my motor factor sells, but there are hundreds of brands out there
MinorMatt wrote:I am using comma MT75 oil in my Mk5 gearbox! I don't have a mk6.
MT75 oil is the wrong thing to use. If you were to use comma you would want comma SX75w90
toricky wrote:MinorMatt wrote:I am using comma MT75 oil in my Mk5 gearbox! I don't have a mk6.
SX75W90 got 2 version GL4 and GL5. Which one suite the VXT75 gear box? Thanks.
darkbluevanman wrote:toricky wrote:MinorMatt wrote:I am using comma MT75 oil in my Mk5 gearbox! I don't have a mk6.
I think GL4 and GL5 just refer's to the 'quality' IE GL5 is better, applies to any oils, I thinks!
Users browsing this forum: Google Adsense [Bot], trektor
