bernies wrote:Ok thank you,
why do you think my oil flicked on then off whilst driving?
bernies wrote:Also if it is loosing pressure when taking left turn or bend, what could be the cause?
bernies wrote:going to put new chain cover on with new crank oil seal and redo sump I suspect pickup tube fault as I have put more oil in and now no light on bends.
Shall I use ford sealant or is there a gasket for these?
Guy88 wrote:bernies wrote:going to put new chain cover on with new crank oil seal and redo sump I suspect pickup tube fault as I have put more oil in and now no light on bends.
sealant for the sump, gasket for the cover,
when you fit the cover use the new crank seal to centre it
Users browsing this forum: Coney
