transit fwd wont engage 4th 5th and reverse gear
Postby tooly68 » Tue Oct 16, 2012 11:25 am
hi all , my transit recently broke down with a gearbox problem, basically the bolt in the selector shaft snapped i repaired this but could not locate the snapped bolt in the gearbox, i had to put the selector back in to move the van but it would only engage 1st 2nd and 3rd gear. any ideas as to what the problem could be,
tooly68
Re: transit fwd wont engage 4th 5th and reverse gear
Postby ake » Tue Oct 16, 2012 6:05 pm
Probably the broken bolt! You need to find it and get it out before it comes through the casing!
Postby tooly68 » Fri Oct 19, 2012 7:28 pm
found the problem, it was the set up of the blue cable , i didnt put it back in the right position, still cant find the bolt tho, :oops:
tooly68
