power upgrade??? just done it.
Postby becky » Sun Jun 10, 2007 9:48 pm
looking to upgrade my luton.
in my ignorance i just thought all mods were a plug in module.
today i`ve been to a car show in bristol. there was a guy whos taking out the ecu and remapping it.
when asked whats the difference to this methoid and a plug in unit.
he says his way is better. on his computer, he can see how the engine proforms, flat spots etc and give it the correct fuel increase in the areas it needs etc. end result a better, smoother engine.
why as a plug and play unit, is an increase bassed on a generic engine, not yours....
of course he would say his way is better, thats what hes selling. a down side is he needs the car/van for a day, or at least the ecu unit... which means no van for a few days.
what is everyones opion on this methoid?
has anyone gone down this route rather than a plug and play unit?
jumbos do it standing up....
becky
I'm a hairy arsed male!!
Postby motorwise » Sun Jun 10, 2007 9:53 pm
no need to remove the ECU it can be flashed in situ - blue fin remaps through the 16 pin OBD socket - or you can buy tuning boxes that plug into the fuel pressure sensor or pump (depending whether you're common rail or not)
blue fin is probably best - have a look here
http://www.mybluefin.co.uk/
http://www.motorwise.net
motorwise
Postby martynx » Tue Jun 12, 2007 7:31 pm
Theres a lot more to tuning than adjusting the fueling - so i'd say for out & out max power the remap would win easily - cant beat a plug in tuning box for convenience though and they can often add a good chunk. Bluefin sounds good but at £500 its a lot to pay for a generic solution - a remap on a good day would be £300 i guess
I had an "ecotune" box from diesel bob (£375) & it added shed loads of torque & little else - my clutch lasted about 50 miles..
Amongst other things a custom remap adjusts "torque limiters" that vary with each gear so you would potentially have a much better overall increase plus you can tell the guy what you want & where you want it & he can map it accordingly ..
Let us know what you decide & the results ?
martynx
Postby becky » Tue Jun 12, 2007 9:44 pm
still trying to find someone really local
don`t want to go too far out
becky
Postby becky » Sun Jun 17, 2007 8:09 pm
just returned from another cars show.
there were a couple of chippers there
the first one only did burgers and chips..... ;-)
the other chipped ( modified the ecu) while you waited.
plugged the laptop into the port under the steering wheel, 5 mins later, he had finished.
upgraded to approx 150bhp. (125 to start with)
Can i tell....... no.
he did say the fuel pump had to slowly rise to the correct pressure, this could take 2 miles or 200.
i`ve just done 100 miles coming back from the show, still no " bolt of lightening" sudden power serge.
we`ll see later.
ps. it cost £200. .. not bad for 5 mins work.
becky
Postby motorwise » Sun Jun 17, 2007 8:12 pm
becky wrote:just returned from another cars show.
we`ll see later.
just far enough away then :wink:
motorwise
Postby 100 T280 » Sun Jun 17, 2007 8:18 pm
becky wrote:he did say the fuel pump had to slowly rise to the correct pressure, this could take 2 miles or 200.
'02 100 T280 SWB Exec. FWD Medium Roof 2.0 DuraTorq TDdi 100ps
College Blue, Alloys, Eberspächer, Twin Batteries, Single Seat,
"Park Distance Control", AirCon, Rev. Counter, 7000RDS.......
100 T280
Rising Pressure
Postby martynx » Sun Jun 17, 2007 8:40 pm
Not heard of that one ! If it turns well £200 is good value though - what was the geysers name / trading name ? did you see what equipment / interface was used ?
martynx
Postby AndyG » Sun Jun 17, 2007 9:20 pm
becky wrote:there were a couple of chippers there
:shock:
Should've gone to the first one :!: :P
Hope you got some sort of receipt :?:
Postby transitgeoff » Sun Jun 17, 2007 9:41 pm
we`ll see later.
il second that, nice £200 for nothing :lol:
transitgeoff
Postby AndyG » Sun Jun 17, 2007 10:22 pm
Image :roll: :(
Postby tranycamperman » Mon Jun 18, 2007 12:00 am
It wasn't Dick Turpin ECU's Ltd was it?
I'll be a little more blunt than the others, you've been add mate :(
Get on the phone and get yer cash back asap.
tranycamperman
Postby becky » Mon Jun 18, 2007 7:59 am
companys name was
chippeduk from bromsgrove.
http://www.chippeduk.com
we were at the GTI international, they were doing golfs all day long.
seemed pro enough, can`t see much when the geezers standing in the door way.
becky
Postby transitgeoff » Mon Jun 18, 2007 8:12 am
golfs might be easy, i know a ford technician and he says he cant upgrade the power and he has the proper ford laptop, he says bluefin is the only way, £200 lesson learnt :!:
transitgeoff
Postby martynx » Mon Jun 18, 2007 9:50 am
Ive heard of Jason of Chipped UK & from what ive seen he has excellent reputation - & pushes this support / customer service thing heavily .. i contacted him about buying tuning equipment last year..
If it actually was him or one of his agents / dealers i'd say he's either telling the truth, or made an error , or the ecu has reset itself ( last ones unlikeley ) either way im sure he will fix it - if you dont have any luck PM me your number & i'll contact him for you & make him aware of the problem .. -
Good luck ..
Martin.
martynx
