Fault code p007f
Fault code p007f
Postby camperman2000 » Tue Mar 08, 2016 10:40 pm
Hi all. Need your help with this fault.
I have a 2002 90bhp 2.4 medium hightop transit converted to a camper. Last year it started to get diesel knock. Replaced the solinoid on the pump reset codes. fault fixed. Then towards the end of the year it lost all power. No revs. Fault code p007f and p0149 reduced fuel etc. Read all the responses on here, that lead me to air temp sensor. Replaced the one on the EGR valve, but not fixed. Tried to locate the first one on the intercooler/airbox, but didn't find. Found the air filter wet through, eureka it cant breath. Replace this fault gone for a few hundred miles. Now the fault is back p007f. Plug in the laptop reset codes, away again. Park it up go back to it, same fault. Now i have looked all over the airbox and intercooler but cannot find this sensor.
Not sure if this other fault i have is connected. He altornator went last month and the speedo bounces when its ticking over. Any help is appreciated Thanks
camperman2000
Re: Fault code p007f
Postby ned » Fri Mar 11, 2016 1:05 am
P007f charge air cooler temp sensor. N
viewtopic.php?f=27&t=209987
viewtopic.php?f=27&t=168296
ned
Postby camperman2000 » Sat Mar 12, 2016 7:45 am
Any idea where the sensor is. Been all over the air intake but cannot find a sensor thanks.
camperman2000
Postby Jim Archer » Sat Mar 12, 2016 7:53 am
On the EGR valve - as you mentioned above.
Reckon you want to be checking the wiring if a new Ford one didn't cure the problem.
Jim
Mk7 140 Jumbo - Vantunered.
289,000 and counting.
Jim Archer
Postby George106 » Thu Oct 27, 2016 1:53 pm
Hi,
having same fault, can anyone advise where exactly to locate on 2.4 Di (on EGR itself?) and possibly what's part number of this sensor?
George
Ford Transit MK6 11/2000 TDDI 2.4 RWD M330 MWB D4FA MT75 Hi Roof
George106
Postby Crankshaft » Thu Oct 27, 2016 2:40 pm
This one
Don't know the part number though
Sent from my SM-G850F using Tapatalk
Crankshaft
Postby knobby1 » Thu Oct 27, 2016 8:51 pm
Does this help..??..#3:
Pn: 1682035
http://www.catcar.info/ford/?lang=en&l= ... NCsyNzI%3D
Postby George106 » Mon Oct 31, 2016 11:52 pm
Thanks, does anybody know what is the approx. resistance of this sensor at around 25-30deg centigrade? I would like to check before ordering new one?
Cheers
George
George106
Postby George106 » Mon Dec 12, 2016 9:47 pm
To answer last question, got replacement sensor, checked resistance of old and new and both have resistance around 24.8ohm at 26deg. ambient temperature.
New sensor did not cure above discussed fault which is still present (can't be deleted from memory or comes back immediately after deletion).
So back to square one, wiring seam to be intact, is there another sensor to check before or close to air cooler?
Thanks for any input
George
George106
Postby Jp25 » Sun Feb 02, 2020 8:47 pm
I have the same fault code P007F, and I have also changed the temp. sensor. I´m really pist off with the van! I cant figure out what is going on.
Please help!
Jp25
Postby Somersetsimon » Mon Nov 06, 2023 10:32 am
We now have this code which won’t delete and an intermittent loss of 80% power but no dash warning. It’s as if the turbo looses all boost. P007b code.
Mk8 460 minibus 2014
Somersetsimon
Postby knobby1 » Mon Nov 06, 2023 7:41 pm
Somersetsimon wrote:We now have this code which won’t delete and an intermittent loss of 80% power but no dash warning. It’s as if the turbo looses all boost. P007b code.
Thread was started well over 7 years ago...best you start a new thread with your issue....it will tend to get lost in old threads.
