Adblue system malfunction
Postby mpar44 » Mon Feb 04, 2019 9:43 pm
I have a 2015 mk8 minibus and have the message adblue malfunction 9miles till engine cut out. Any ideas ? It's full of adblue and can't reset it.. Can it be diagnosed with ids software or reset
mpar44
Re: Adblue system malfunction
Postby loot » Tue Feb 05, 2019 4:47 pm
Did minibus euro 5 get adblu system? I thought it was late 2016 then euro 6 :?
Ids will do what it is intended to, my brothers was a doser/sensor problem i think.
Ids map here
loot
Postby dumper » Tue Feb 05, 2019 5:01 pm
Yes Loot Euro 6 came in a year ish earlier for psvs even for Minibuses if I’d bought a van of the same year it would be a Euro 5
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
2006 350 jumbo 135 tdci
dumper
Postby mpar44 » Tue Feb 05, 2019 11:19 pm
X think I'll need to invest in some ids software as I now have around 15 of these vans and obviously can't send them to the dealer every time there's a problem.....
mpar44
Postby mwngbot » Thu Feb 07, 2019 12:20 pm
I've had exactly the same issue come up on 2 different Transit Minibuses at the same time. In house mechanic couldn't work out the issue, so had to take them both to the dealer.
They've claimed that the issue with the first vehicle (15 plate, 17500 miles) was solved by draining the tank and refilling it with their own Ad Blue. They have claimed we used an 'inferior product' - but we've always used the Carlube Ad Blue we get from Andrew Page. Always kept between the temperature range and always used within the specified timescale.
On the second vehicle (a 64 plate, 17500 miles ) they've claimed that they've had to update software to clear the fault as the draining didn't work. However, I'm convinced this is a total fabrication as the first invoice was only for £110, so I think they've made up the difference with bullshit on the second invoice. If however that isn't total bollocks, then they've tried to charge me two lots of £115 to update software to make the vehicle start, which I angrily told them was totally highwayman like :x
mwngbot
Postby mpar44 » Tue Feb 19, 2019 9:37 am
I’ve had the problem resolved. Had to get the software update and all is good now.
mpar44
Postby mwngbot » Wed Feb 27, 2019 2:10 pm
Update on my two, is firstly that it is now three.
Number 1 that was 'solved' by a software update was not solved as the error message came back after about 200 miles. Since then, it has been back to the dealer, and they told us it's a faulty sensor on the pump, and they'd need to replace the entire pump at a cost of £780. They've done that, and it hasn't fixed the problem :lol: Still in the garage.
Number 2 was cleared by just putting in different Ad Blue apparently. Error has not reoccurred yet...
Number 3 (15 plate, 14,000 miles) has gone in today, so I cannot wait to find out what is wrong with this one :roll:
mwngbot
Postby martynx » Fri Mar 08, 2019 6:06 pm
Not sure on 2015, sounds early, but there are some MK8 Euro 6 2.2 ( 2200cc not 2000) Ad-Blu Minibuses about.
martynx
Postby rudolfsmate » Thu Oct 10, 2019 5:09 pm
Took delivery of a 19 plate in August and getting this error message. Saying engine won't start after 195 miles. Contacting the dealership.
rudolfsmate
Postby cts1975 » Thu Oct 10, 2019 7:02 pm
I have a 2015 minibus with a similar problem.
Did they discover what the problem was?
cts1975
Postby chipper » Mon Jan 03, 2022 1:17 pm
Hi
I took delivery of a mk8 L2h2 in 1st sept 2021
Had adblue malfunction come up after 1800 miles also electrical wiring problem with adblue system seemed to be intermittent
took to the dealers had the van for 3 days checked all of the wiring loom on adblue system and decided to change the adblue tank sorted
week before came back again,
now waiting for two new wiring looms to arrive at dealership from Germany van got to go back in for two days when they arrive
the technician was great and explained that it had a problem since new he thought as system originally flagged up at 900 miles
I'm hoping this will fix it
chipper
Postby dumper » Wed Feb 09, 2022 10:01 am
My 65 plate x minibus had a problem with the heater in the bottom of the tank since it has been changed it seems to use a lot more adblue now what mpg per litre is normal for a 2.2 euro 6 thanks
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
dumper
Postby Dazmeister » Mon Apr 04, 2022 3:04 pm
We had the adblue issue with our 190k 68 plate 2.0 which the dealer had trouble diagnosing.
Despite having adequate levels of adblue it said it didn't have any miles left so wouldn re-start.
Turned out to be a blocked catalytic convertor.
Dazmeister
