Early 35 pin ECU and epic pump needed
Postby mcwayne » Mon Feb 12, 2018 2:25 pm
Hi Guys looking for 1993-94 Early 35 pin ECU non pats 947 DOWLA 80263N 02010008 32824
also
Epic Pump DSA947- 8720A004A
anything considered but a matched pair would be really nice... We can all dream!
mcwayne
Re: Early 35 pin ECU and epic pump needed
Postby Frag » Mon Feb 12, 2018 7:22 pm
I should have an ECU,can't help with pump I'm afraid,
Can't check the numbers while Wednesday now tho...
Frag
Ford Technician
Postby mcwayne » Tue Feb 13, 2018 10:13 am
Cheers Frag!!
mcwayne
Postby MinorMatt » Wed Feb 14, 2018 1:52 pm
The pumps and ECUs arn't matched together... any DSA947 will go straight on and work as well as any other.
95 M Ford Prototype/Mule DRW 100PS Highcube
96 N 120 Turbo'd DI SWB Low
96 P 150 TD (100PS EPIC) LWB Hi-Top
Lucas laser 2000 & IDS onwner
Gaffa tape is like the force - it has a light side, a dark side, and it holds the universe together.
Postby Frag » Wed Feb 14, 2018 6:45 pm
This...
Frag
Ford Technician
Postby mcwayne » Wed Feb 14, 2018 7:41 pm
Hi Frag, the ecu does appear to be an earlier version than mine but could be worth a try. Do you know anything about it such as it's working condition. Some problems can be added by trying to match components with different part no's something I have learned this through great pains. It's usually more difficult if one adds a faulty Ecu as you can't be sure if it's an incompatibility issue or a fault with the unit. Hence my reason for " the matched pair" anyway i would be happy hear how.much you want for it.
Thanks again.
mcwayne
Postby Frag » Wed Feb 14, 2018 8:02 pm
It's a good ECU,fault was in pump connector.It was off the first EPIC transit we ever had a problem with.....,A 'K' plate mk4,been in my bench since 93/4.....
What problem are you trying to fix ?
Why do you need an ECU and pump ?
Frag
Ford Technician
Postby mcwayne » Thu Feb 15, 2018 10:20 pm
Im still in the process of diagnosing. The engines a non starter due to fuel not passing thro the pump. I put a scope on last week and eliminated most of the engine sensors, which tells me to some degree the ECU is working. Ive eliminated the Esos but ran out of time on the remaining pump valves, hope to check over the weekend. I 've narrowed things down to pump or ecu. I do have laser 200 but need a cable ywb 758. I would also like to get a epic cable connector and ecu 35 pin plug or a wiring harness complete i guess. I did get a Modis and laser 2000 connected but they both threw up data corrupt, which raised my suspicion on the ECU fault. Did strip down the ECK visibly everything looks fine so still searching for the answer.
mcwayne
