Wanted- Bracket for Rear Stabiliser Bar
Postby ozzie_traveller » Sat Mar 23, 2024 11:19 pm
G'day all
Transit= VH, 2003-4, LWB,
Seeking a bracket (image below) for the rear stabiliser that bolts onto the diff
I have been thru 6- Aussie breakers with no success (I think that it's too small for them to bother with, so I'm getting no-where)
Thanks, Phil
Response info here or email ... Ozzie_Traveller@Yahoo.com
ozzie_traveller
Re: Wanted- Bracket for Rear Stabiliser Bar
Postby andz327 » Fri Mar 29, 2024 2:42 pm
Can't you use or modify a front one, those are not a common item on transits probably just the double rear wheel transits
What's up with yours??
andz327
Postby ozzie_traveller » Sat Apr 13, 2024 11:39 pm
G'day all
To answer the above Q ... one of the two brackets was lost allowing the whole sway bar to squeak badly when rubbing metal-on-metal and permit more body roll than I was comfortable with
In the absence of obtaining a OEM bracket, I have had a simple replacement item made up and installed - hoping that it will do the job okay
Thanks again, Phil
ps- mods ... can this item be marked as 'closed' please
ozzie_traveller
