Mk7 LWB RWD 6 Speed Prop shaft *NO LONGER NEEDED*
Postby anynamewilldo » Sat Aug 16, 2025 10:58 am
Does anyone have a mk7 prop shaft for a 6 speed lwb they can sell/swap?
CatCar link
Currently trying to split the splines on the existing one and they're seized to the point where a replacement seems like it might be needed. UJ's on current one are fine, just one of the centre bearings needs replacing. Otherwise no issues with the existing one so can swap/trade.
South west area ideally
anynamewilldo
Re: Mk7 LWB RWD 6 Speed Prop shaft
Postby Harvy » Sun Aug 17, 2025 9:31 am
I’m afraid I don’t have one available. Have you tried any heat (blowtorch) to heat up the outer female part of the splines? When I changed my centre bearing my driveshaft just slid apart with no effort whatsoever. I’m not trying to boast but I would be surprised if you couldn’t loosen it off with some heat. Good luck.
2010 T350 LWB H3 RWD 2.4 115 Full poverty spec! :D
Harvy
Postby anynamewilldo » Wed Aug 20, 2025 3:33 pm
No longer needed - got a replacement sorted
anynamewilldo
