Transit Euro 4 fwd vnt electronic turbo
Re: Transit Euro 4 fwd vnt electronic turbo
Postby loot » Sat Mar 13, 2021 11:15 pm
Yep, hopefully a reset and clear out will wake it up 8)
Ids map here
loot
Postby andz327 » Sun Mar 14, 2021 3:38 pm
What mileage is on asbo
Sent from my LG-H870 using Tapatalk
andz327
Postby loot » Sun Mar 14, 2021 9:29 pm
147k I think.
Is smoking and holding back today, it beeps at ignition on and the mil is still on, it should have cleared so I need to read codes, similar problem to my turbo. Maybe the nozzle is blocked although it seemed smooth enough, maybe actuator had broken wire. Needs investigating.
Ids map here
loot
Postby andz327 » Mon Mar 15, 2021 11:50 pm
It ran perfect with me mate so dont be stripping doon that turbo noo ,
You've No abs sensor problems do you z??
andz327
Postby loot » Mon Mar 15, 2021 11:58 pm
andz327 wrote:It ran perfect with me mate so dont be stripping doon that turbo noo ,
It might be my actuator as it seems to be the common denominator, if I unplug it then there's absolutely no smoke (maybe defaults) and there's no torque at all.
Done nearly everything now apart from check the exhaust, I tapped the cay to make sure it wasn't rattling inside.
Ids map here
loot
Postby andz327 » Tue Mar 16, 2021 2:53 am
Want the one for that turbo posted mate ??
andz327
Postby loot » Tue Mar 16, 2021 4:36 pm
Would you.? It'll mean that it isn't the turbo then, :P
Cheers. Tell me what I owe you too or I'll send some provocative pictures of me posing for unfinished projects weekly :lol: :D
Ids map here
loot
Postby andz327 » Wed Mar 17, 2021 9:31 pm
loot wrote:Would you.? It'll mean that it isn't the turbo then,
Cheers. Tell me what I owe you too or I'll send some provocative pictures of me posing for unfinished projects weekly :D
Hahaha you know the troops will hold you to that..... Well maybe not hold you but nae pictures means it didn't happen you know the rules
Is it black smoke ?
andz327
Postby loot » Wed Mar 17, 2021 10:44 pm
Yes, proper if u floor it and there's no power at all. If I unplug the actuator it must default because there's no power the same as but no smoke at all. That must rule out a lot of things.
Might need to set fire to it :shock:
Ids map here
loot
Postby loot » Thu Mar 18, 2021 9:08 am
Right so i have p0299
Low turbo boost, I had the eml on for a week since the repair and cleared it today then read it again at work 3 miles later and no eml but that code.
So ill check if the actuator is moving, I'll also fit the new egr again
Ids map here
loot
Postby andz327 » Fri Mar 19, 2021 11:51 am
The only time mine ever blew black was when there was a pinhole rubbed through on the clearish fuel pipe that runs to pump, rubber water hose was sitting on the fuel pipe and rubbed it through and cause the hose was on the hole it blocked the hole so ran normal until you accelerate then you get problem again ...... Drove me nuts hahaha
andz327
Postby ned » Fri Mar 19, 2021 12:02 pm
I’ve blew black smoke when the boost pipe was split, it makes me wonder if you have a boost leak somewhere especially as it’s only rolling coal when the actuator is plugged in.
My reasoning for this is the pcm is seeing boost so upping the fuel but the fuel air mix isn’t correct in the cylinder creating black smoke.
viewtopic.php?f=27&t=209987
viewtopic.php?f=27&t=168296
ned
Postby andz327 » Fri Mar 19, 2021 12:02 pm
Mine throws up high boost and low boost codes at times but put it down the stuck egr
Let me know if you still want actuator and ill look it oot mr loot and send it oot later today or tomorrow morning and should get to you Monday
andz327
Postby andz327 » Fri Mar 19, 2021 12:04 pm
ned wrote:I’ve blew black smoke when the boost pipe was split, it makes me wonder if you have a boost leak somewhere especially as it’s only rolling coal when the actuator is plugged in.
Hope no hahaha hes been chasing it for over a week
andz327
Postby ned » Fri Mar 19, 2021 12:34 pm
:lol: :lol: Think it’s been smoking since December, I believe the intake manifolds can split on the mk7 but I may have dreamt that
ned
