Egr pipe for mk6 2004 2.0DI
Postby Plumbtek280 » Thu Jul 10, 2014 3:36 pm
Hi all, on the off chance has some one out there got an egr tube/pipe for sale. its the pipe that runs from the egr valve across the front of the engine and then round to the inlet manifold. mine has a quite large hole in it and makes the thing sound like a bloody tractor with no exhaust! :(
Again the van is a mk6 2004 2.0DI 100ps
Any help would be appreciated
Many thanks
2004 100/T280 Duratorq DI, Electrics pack, Front fogs, Rust!!
Plumbtek280
Re: Egr pipe for mk6 2004 2.0DI
Postby Altransit » Thu Jul 10, 2014 11:33 pm
I just blanked off both ends on mine 8) , that pipe is megabucks for what it is :(
Postby Plumbtek280 » Fri Jul 11, 2014 2:27 pm
Altransit wrote:I just blanked off both ends on mine , that pipe is megabucks for what it is
Went and got one today from the local stealer! managed to get it for £140 all in which aint too bad. nice and new and shiny as well!! 8)
Fitting it this afternoon, should improve the sound!
The van cut out on me yesterday though. the hole couldn't be the cause could it Altransit?
Cheers
Plumbtek280
Postby Altransit » Fri Jul 11, 2014 6:22 pm
It never caused that problem on mine, it was noisy and down on power until we found the fault, but blanking the ends made it run better than before, because it disabled the EGR valve 8)
Postby Plumbtek280 » Sat Jul 12, 2014 12:31 pm
Altransit wrote:It never caused that problem on mine, it was noisy and down on power until we found the fault, but blanking the ends made it run better than before, because it disabled the EGR valve 8)
All seems much improved after fitting the pipe. the van has so much more power, is a lot quieter and so far it hasn't failed to start or cut out on me
Result!!
very happy boy :D
Plumbtek280
Postby benzuddhist » Fri Aug 31, 2018 5:12 pm
Scusi... whaddya mean you "banked" both ends. My EGR piped broke clean so I have fixed it for the moment with a baked bean can wrapped round it and some jubilee clips. Works a treat. Not sure how long it will last though!
Any other ideas? The van ain't gonna last long so I don't really want to spend £220 on a new EGR pipe.
~Cheers,
Ben
benzuddhist
