mk5 brake servo and master cylinder DOHC petrol!
Postby familybanger » Sat Apr 23, 2016 8:24 pm
Yep one of them. Are they hens teeth or am I just rubbish at looking?
It's different fro the diesel ones have tried to make a good one out of existing and diesel one I picked up but no joy. All help, abuse taken in good jest . Thankyou please.
familybanger
Re: mk5 brake servo and master cylinder DOHC petrol!
Postby mrepson » Sun Apr 24, 2016 2:36 pm
I think I have one off a petrol tourneo, does yours have abs, :?: as I think mine did,i will look & send you a pm :D
mrepson
Postby familybanger » Sun Apr 24, 2016 5:04 pm
Much appreciated☺ no abs on mine, how different could they be?
I'll get a pic and post it up.
familybanger
Postby Luke » Sun Apr 24, 2016 5:11 pm
what's the difference in a petrol and a diesel one?
Postby mrepson » Sun Apr 24, 2016 6:31 pm
are the pipe fitting bigger,or has less fitting on the mastercylinder, :?: I will get it out & check,
mrepson
Postby MinorMatt » Mon Apr 25, 2016 11:36 am
I can sell you a DOHC van (completely roadworthy) with a good master cylinder on it??? :lol:
95 M Ford Prototype/Mule DRW 100PS Highcube
96 N 120 Turbo'd DI SWB Low
Lucas laser 2000 & IDS onwner
Postby familybanger » Mon Apr 25, 2016 8:41 pm
Luke wrote:what's the difference in a petrol and a diesel one?
Less pipes coming out of master cylinder, different bolt spacing for cylinder (though could be engineered) , different spacing for bulk head (again could be adapted ). Did think of I could adapt brake lines and do a two into one split but decided I wouldbe messing with forces I don't fully understand :lol: was a bit worried it would lead to dodgy bias situation too.
I'll add pics when I can though can't do it from my phone. Should be able to sort weds from work computer :D
familybanger
Postby familybanger » Mon Apr 25, 2016 8:44 pm
MinorMatt wrote:I can sell you a DOHC van (completely roadworthy) with a good master cylinder on it??? :lol:
Those dohc vans are rubbish, Id brake it for parts if I were you :lol:
familybanger
Postby MinorMatt » Mon Apr 25, 2016 9:41 pm
You sure thats not just down to age of the vehicle?
You can buy it for £600 to break if you want... you could even drive it home
Postby familybanger » Sat Apr 30, 2016 1:56 pm
I jest. The van's great and hope yours finds a good home matt. My vehicle quota is overfull as ever so no more for me at present, am trying to thin out and fix what I've got.
Just taken some pics will try get them up.
familybanger
Postby familybanger » Sat Apr 30, 2016 1:58 pm
Oh my it worked☺
So as you see its steel and rusty and has three pipes attached.
familybanger
Postby MinorMatt » Sat Apr 30, 2016 10:37 pm
Thats just the early mk5 setup... Same and my N reg diesel
I will compare with my DOHC tomorrow
Postby MinorMatt » Sun May 01, 2016 5:39 pm
The master cyl is definately the same as my N reg Di, and the master cyl on my S reg DOHC is the same as on the X reg 2.5DI I am breaking at the moment...
Postby familybanger » Fri May 06, 2016 10:40 am
Many thanks Matt. Think i,ve found one at a breakers in Hythe :D
familybanger
Postby sportscott » Wed Oct 04, 2017 10:21 pm
MinorMatt wrote:The master cyl is definately the same as my N reg Di, and the master cyl on my S reg DOHC is the same as on the X reg 2.5DI I am breaking at the moment...
Hi Matt, with hind site after reading through previous posts you seem to be the one who provides the answers. If the master cylinders are the same does that mean the servos are the same?
Transit the everyday mans van....
sportscott
