MK3 Diesel Clutch Pedal
Postby Philbr » Sat Feb 03, 2018 4:45 pm
Hey,
Does anyone know where I can source an original clutch pedal for a MK3 diesel?
It was a petrol but has had a 2.5 diesel put in so have been told that I need a certain pedal if that makes a difference?
Thanks in advance.
Philbr
Re: MK3 Diesel Clutch Pedal
Postby Mr RVM » Fri Feb 09, 2018 3:13 am
Philbr wrote:Hey,
Thanks in advance.
Thought they were the same....... :?: :?: :?: .......but being a Mk3 it will have the self adjusting ratchet quadrant and cable.....some would say you'd be better off with the manually adjusted version from Mk5......get one from a scrapper.....10 min job to change.....I'd fit a brand new cable while you're on :wink:
Mr RVM
Postby BROWNYS V6 » Fri Feb 09, 2018 7:42 pm
got a mk3 pedalbox at work, dunno if its a ratchet clutch one though, will have a look tomoz, fitted a mk2 pedal on mine and used a mk2 cable=no ratchet :wink:
BROWNYS V6
Postby Philbr » Sat Feb 10, 2018 2:37 pm
Thanks for the replies!
Yes mine is welded to a fixed point and I have been told I need the self adjusting original as mine could go whenever!?
Will have a look into both the Mk2 and 5 options you have both mentioned, thank you.
Philbr
Postby Chug » Sat Feb 10, 2018 3:48 pm
Make sure whichever pedal you go for to get the matching clutch cable too, the self adjusting ones can be made to stop slipping on the ratchet by using a small coin, or a suitably sized washer, placed in the mechanism to stop the ratchet pawl from lifting.
Chug
Postby Philbr » Mon Feb 12, 2018 8:55 am
Chuggy wrote:Make sure whichever pedal you go for to get the matching clutch cable too, the self adjusting ones can be made to stop slipping on the ratchet by using a small coin, or a suitably sized washer, placed in the mechanism to stop the ratchet pawl from lifting.
Ok thank you!
Whatever I find will post up here.
Philbr
