Oil cooler assembly
Oil cooler assembly
Postby Airthies » Thu Jan 03, 2019 9:45 pm
Looking for a 2.2/2.4/3.2 oil filter/cooler mounting housing.
Doesn't need to be one that's fit to use as planning on cutting it to bits but don't want to buy a new one to cut it and find my plans not going to work.
Like the one in the pic.
Looking to make a remote filter Image
Back now, well for a bit anyway.....
2008 350LWB 115PS ex fitters van + other things....
V86+patch
V86.04
X-Prog
C81
Airthies
Re: Oil cooler assembly
Postby andz327 » Fri Jan 04, 2019 8:40 pm
Airthies wrote:Looking for a 2.2/2.4/3.2 oil filter/cooler mounting housing.
Is the 2.4 same as 2.2 ??
I should have one somewhere when i changed to the canister type
ANDZ
andz327
Postby Airthies » Fri Jan 04, 2019 8:54 pm
Think it's the same but not entirely sure
V86+patch
V86.04
X-Prog
C81
Airthies
Postby bambi mk 1 » Fri Jan 04, 2019 9:32 pm
FWD coolers wont fit RWD :wink:
Theres the good guys,theres the bad guys but there only ever be one SPEED GUY
bambi mk 1
Postby karl » Fri Jan 04, 2019 9:47 pm
bambi mk 1 wrote:FWD coolers wont fit RWD :wink:
is that because they are smaller ?
the one iam sending him is a rwd drive one :D
karl
Tranny Lover!!!
Postby Airthies » Fri Jan 04, 2019 10:33 pm
It'll fit wherever I dam well put it! it's fr a remote filter project but one the same as the one that on at the mo would be better
Is the 2.2 FWD diferent than the 2.2 RWD?
Or is it just 2.0 FWD as I know that's not the same!
V86+patch
V86.04
X-Prog
C81
Airthies
Postby Airthies » Fri Jan 04, 2019 10:36 pm
andz327 wrote: I should have one somewhere when i changed to the canister type
ANDZ
If I can sort out a plan I was thinking of getting a spin on filter one for the final assembly.
V86+patch
V86.04
X-Prog
C81
Airthies
Postby andz327 » Tue Jan 08, 2019 11:17 pm
ANDZ
Fwd definitely different from rwd mate
andz327
Postby Airthies » Tue Jan 08, 2019 11:43 pm
Hmmm... pants
V86+patch
V86.04
X-Prog
C81
Airthies
