MT75 Mechanical Speedo Drive. Or Gearbox swap
Postby 103keef » Sat Jan 12, 2019 8:33 pm
So I have an MT75 Diesel Box that I'm putting in a MK2.
It's got the Electronic Speedo Drive so I'm looking for a Mechanical one. Speedo Cable would be useful as well.
Alternatively, I'd consider swapping Gearbox's with someone.
103keef
Re: MT75 Mechanical Speedo Drive. Or Gearbox swap
Postby Kev1000s » Thu Jan 31, 2019 8:52 am
I have mt75 box and speedo cable £60
Regards Kev
Ford FDS 2000
52 plate , Smiley 150lwb ,Td,Ex police :)
1996 Smiley 100 ,Td-Intercooled , lowered 50mm,mk6 wheels,lsd 4.11..
Kev1000s
Postby sportscott » Mon Feb 25, 2019 2:26 am
103keef wrote:So I have an MT75 Diesel Box that I'm putting in a MK2.
You don't need to swap the gearbox, you can convert it from electronic to cable easily. All you need is the pinion drive wheel, a cable and an oil seal, loads on here about in fact Minor Mat has a good post about it. I am searching myself for how the electronic sensor is wired because need to get a feed for my cruise control as I've thrown the magnets from the prop shaft.
Transit the everyday mans van....
sportscott
