140 turbo actuator
140 turbo actuator
Postby lancy » Wed Feb 20, 2019 12:43 am
Hi all!! Im after a turbo or turbo actuator for a 2.4 140 for my 2008 jumbo??
Thanks! :)
lancy
Re: 140 turbo actuator
Postby martynx » Fri Feb 22, 2019 4:12 pm
These guys are good, not 100% if they currently offer a service on Transit actuators though.
https://bba-remanshop.com/gb/product/turbo-actuator-repair-service/
Replacements units are available on ebay sometimes as well, Either way, look at your G number, on the body of the actuator, etched. "G32" or similar. You wont be able to see it till its removed normally as its feint , take care to replace for the same type if getting a replacement rather than having your unit repaired. ( assuming your one currently is the original / correct one)
martynx
Postby lancy » Sun Feb 24, 2019 10:44 pm
Hi thanks for your time, ill give them a look!
One question will this cause trouble, non starting?? As mine now wont start unless with spray and bearly at that now, ive had to revert to bump start recently, and i know this is not good for these engines :shock:
lancy
Users browsing this forum: Baidu [Spider]
