Wanted Epic accelerator pedal mk5 (i think)
Postby Carolsvan » Sat Jul 13, 2019 3:16 pm
I am looking for an epic accelerator pedal from a mk5 transit.
I have a 1999 LDV convoy and have been told the mk5 pedals are same.
My pedal is ok mechanically but the potentiometer is faulty.
If anyone can help Id be so grateful.
Carolsvan
Re: Wanted Epic accelerator pedal mk5 (i think)
Postby Carolsvan » Sat Jul 13, 2019 4:37 pm
UPDATE
Forgot to mention its a 2.5DI
Carolsvan
Postby mrepson » Sat Jul 13, 2019 10:26 pm
where are you at, :?:
mrepson
Postby Altransit » Sat Jul 13, 2019 10:32 pm
mrepson wrote:where are you at, :?:
From another post, Coventry :)
Postby Carolsvan » Sun Jul 14, 2019 7:44 pm
Yes Coventry.
Are all the pots the same just different pedal?
Carolsvan
Postby Luke » Sun Jul 14, 2019 7:57 pm
can the potentiometers be repaired?
Postby Carolsvan » Mon Jul 15, 2019 1:37 am
Luke wrote:can the potentiometers be repaired?
Don't think so , the way it was explained to me is they are like volume controls and they wear out , so a volume control worn out the sound gets all crackly due to worn contacts so with this it gives crackly signals to the engine computer.
Only what I have been told though :D
Carolsvan
Postby Carolsvan » Mon Jul 15, 2019 5:06 pm
Don't even need the whole pedal just the potentiometer
Carolsvan
Postby paulmusescu » Tue Jul 16, 2019 10:50 am
"Description of Operation:
The assembly comprises:
A ‘reverse’ twin–pack potentiometer (PDS1 & PDS2)
A ‘low pedal–demand’ (idling position) switch (LPDS)
A ‘high pedal–demand’ (kick–down position) switch (HPDS)
NOTE
A ‘reverse twin–pack potentiometer’ comprises a pair of potentiometers mounted on the same shaft and arranged so that when one of the pair presents a high voltage at its output, the other presents a low voltage.
The two switches are for validating the pedal sensor values. With no throttle response i.e. engine stationary or at idle, LPDS is open and HPDS is closed. At part–throttle, both switches are closed. At full throttle, LPDS is closed and HPDS is open.
HPDS is also used to initiate automatic gearbox kick–down.
The potentiometer assembly is part of the LDV pedal assembly and is non–repairable. It must be replaced if faulty."
More about: https://www.ecovippari.com/uploads/6/4/ ... manual.pdf
1999 Ford Transit Smiley 2.5 Turbo Diesel, manual gearbox, transformed to a camper.
paulmusescu
Postby MinorMatt » Tue Jul 16, 2019 11:54 am
LDV and transit pedals are not the same, and the bits arn't an easy swap either. You need an LDV pedal
95 M Ford Prototype/Mule DRW 100PS Highcube
96 N 120 Turbo'd DI SWB Low
Lucas laser 2000 & IDS onwner
Postby Carolsvan » Tue Jul 16, 2019 12:15 pm
MinorMatt wrote:LDV and transit pedals are not the same, and the bits arn't an easy swap either. You need an LDV pedal
Cheers matt
Carolsvan
