loot wrote:Certainly does, all i did on the front bit is cut a bit off the original door card and cut a bit off the pocket so it kind of locks inside them screw through them both. Apart from that it fits perfect. Just make sure you get the square clips as they push into square holes behind the blanks or it'll never go on.
Don't know why they are rare lol
bambi mk 1 wrote:Must be because I have about 50
loot wrote:You screwed into the black plastic blanks Ned?fair play if it works
loot wrote:Which 1 mate? The lower 1 as in the mod?
I used mine the other day but I have 2 spare doors, both left and I think some right door bits too like glass and quarter, also a mix of electric and manual winder.
dirtydog wrote:loot wrote:Certainly does, all i did on the front bit is cut a bit off the original door card and cut a bit off the pocket so it kind of locks inside them screw through them both. Apart from that it fits perfect. Just make sure you get the square clips as they push into square holes behind the blanks or it'll never go on.
I've seen the square clips, some bloke is selling a pack of 20 on eBay for nearly £30. Need to measure the square holes so I can just buy some generic ones
Users browsing this forum: Baidu [Spider]
