HELP NEEDED STUCK IN HOLLAND,LUCAS CAV 2.5DI PUMP NEEDED,
Postby mrktodd » Mon Aug 05, 2019 8:22 pm
Been stuck in a marina in holland.....our boats 2.5di banana engine....lucas can pump snapped anyone got one???
Waited a week for a bosch pump and injectors....put on and won't even attempt to fire.
Decided to go back to lucas.
Please help we are stranded.
Thanks I advance,Mark.
mrktodd
Re: HELP NEEDED STUCK IN HOLLAND,LUCAS CAV 2.5DI PUMP NEEDED
Postby Luke » Mon Aug 05, 2019 8:29 pm
when you fitted the bosh pump did you use the lucas pipes? i seem to remember years back i swapped one and the firing order was different between the 2 pumps so i needed the bosch pipes too.
Postby mrktodd » Mon Aug 05, 2019 8:34 pm
Yes used the bosch pipes and injectors.....doesn't Even attempt to fire....as if timing is way out.
All pinned correctly,and tried advancing and retarding pump...nothing.
Starts on wd 40.so assume motors still good.all air bled and injection pipes spurting diesel.....any one any ideas??
mrktodd
