Hi I need a couple of parts only small but I don't mind paying enough to make it worth your time.
First thing I need is the clip that goes on the Injection pump end of the throttle cable Item 14 on the diagram
Then I need the propshaft center bearing mounting bracket I need to fit the part that bolts to the bottom of the van with 4 torx head screws (and the 4 screws as mine aren't it a good way)
I have a propshaft from a swb mk5
It's going into my 1992 mk4, my current one is to far back to accept the mk5 prop, the center support needs to bolt on about 100mm forward my current bracket looks like item 6
Looks like I need item 8 to make it fit correctly
If anyone can help with any of these I'll be very grateful.
