injector pump mark 6 2.0l
Postby borosteve58 » Sat Jan 18, 2020 2:22 pm
where can i get a diesel injector pump for a mark 2.0.l 260 swb transit
borosteve58
Re: injector pump mark 6 2.0l
Postby ned » Sat Jan 18, 2020 4:43 pm
Pf Jones
viewtopic.php?f=27&t=209987
viewtopic.php?f=27&t=168296
ned
Postby dieselhead123 » Tue Jan 21, 2020 12:07 am
borosteve58 wrote:where can i get a diesel injector pump for a mark 2.0.l 260 swb transit
You have a number of different options for replacement, the one you select will depend on the amount of money you are prepared to spend on your vehicle.
You can purchase new, this could be from Ford or a Bosch agent.
Re-conditioned units can be purchased on an exchange basis, Ford, a Bosch agent or almost any propriety vehicle trade parts supplier should be able to help you.
The last option, and the lowest cost, would be to purchase a pre-used unit.
In the unlikely event that your 260 is a Tdci then please substitute "Delphi" for "Bosch" in the above comments.
Have a phone around a number of different suppliers to get some price quotes for new/re-conditioned units. If you would like to purchase a pre-used unit then we can supply the part and post it to you. All our Tddi pumps are supplied 'pre-virginized' saving you the additional cost of getting the pump 'coded' to your vehicle. Note; 'Coding' the pump to your vehicle will not be required if it is a Tdci model.
