Mk8 axle 3.73 ratio
Mk8 axle 3.73 ratio
Postby Airthies » Wed Feb 05, 2020 12:06 am
Anyone know of a reasonably priced Mk8 single wheel axle with a 3.73 ratio diff?
Sent from my A55ho11 using Crapatalk
Back now, well for a bit anyway.....
2008 350LWB 115PS ex fitters van + other things....
V86+patch
V86.04
X-Prog
C81
Airthies
Re: Mk8 axle 3.73 ratio
Postby loot » Fri Feb 07, 2020 12:19 pm
You thinking lsd?
07 350 170ps
[img]http://[/img]
Ids map here
loot
Postby Airthies » Fri Feb 07, 2020 12:36 pm
loot wrote:You thinking lsd?
Yes but been doing some research myself as couldn't find what I wanted to know, but sofar to say, I don't think I need a Mk8 diff now, got some plans a hatching
V86+patch
V86.04
X-Prog
C81
Airthies
Postby loot » Fri Feb 07, 2020 1:09 pm
Diff lock for off road 8)
07 350 170ps
[img]http://[/img]
Ids map here
loot
Postby Airthies » Fri Feb 07, 2020 1:30 pm
loot wrote:Diff lock for off road 8)
When looking at the Mk8 axle, that apparently has an LSD option in the states, it's not that much different from the mk7 to look at it, so stripped the one I've got sitting here to check dimensions etc, so going to stick with the mk7 axle and do some mods Image
V86+patch
V86.04
X-Prog
C81
Airthies
Postby andz327 » Sat Feb 08, 2020 5:44 pm
SORTED maybe get screechy tyres in the summer though mate
16yr ago i had ex lecky board blue and white N reg 2.5 turbo with lsd and it was screechy fooker at low car park speeds..... great auld van
Sent from my SM-G975F using Tapatalk
andz327
croncroncron
