Flywheel required 1994 2.5D
Postby alanwetherall » Wed Mar 04, 2020 5:26 pm
We use a 2.5 diesel engine 1approx year 1994 (The banana smiley engine) and the flywheel has seperated itself from the end of the crankshaft. Would anybody know where i can find a replacemnet flywheel
many thanks
alan wetherall
07703438481
alanwetherall
Re: Flywheel required
Postby knobby1 » Wed Mar 04, 2020 8:46 pm
Is it the flywheel broken, flywheel bolts broken or the crank broken..?? Strange either way.
Re: Flywheel required 1994 2.5D
Postby Keef » Thu Mar 05, 2020 1:42 pm
I had this happen on a Morris Minor years ago, the bolts worked loose and the flywheel was banging about making 'big ends gone' noises but still driving and changing gear fine.
I pulled the engine to fit a replacement and saw the loose flywheel so just refitted it with new bolts and tab washers and was good as gold from then on.
Keef
Postby MinorMatt » Sat Mar 07, 2020 7:27 pm
I definately have a spare flywheel which would suit - but as above thats a very rare issue... are you sure its the problem?
