Dual alternator setup, tachograph
Postby GreaseMonkeyuk » Fri Apr 03, 2020 8:49 am
Hi guys hope your all well and keeping safe in these crazy times
Got a couple parts I'm after and hoping someone can help me out
Mk7 transit I'm looking for a dule aultornator set up the bracket aultornator etc
In also looking for a tachograph speed sensor for a 6 speed RWD gear box and the cable
Thanks in advance
GreaseMonkeyuk
Re: Dual alternator setup, tachograph
Postby Airthies » Sun Apr 05, 2020 7:12 am
GreaseMonkeyuk wrote:Hi guys hope your all well and keeping safe in these crazy times
Thanks in advance
What's the plan with the tacho sensor?
Sorry can't held with any actual parts.
Bikes, yes, a few bikes.
V86+patch
V86.04
X-Prog
C81
Airthies
Postby GreaseMonkeyuk » Sun Apr 05, 2020 10:04 am
Thanks in advance
Got to install a tachograph for what I use the van for
Local guy here will do it a lot cheaper if I can do as much as I can my self
GreaseMonkeyuk
Postby Airthies » Sun Apr 05, 2020 12:20 pm
Ah right. Wasn't sure if it was just a speed signal you needed as the pcm has an output for that.
Try some of the transit pages on FB for folk breaking one with a tacho and get the full factory kit?
Actually I didn't think the MT82 box has a speed sensor or anywhere to fit one?
As vehicle speed is all done via abs module from wheel sensors.
V86+patch
V86.04
X-Prog
C81
Airthies
Postby andz327 » Sun Apr 12, 2020 1:36 am
Airthies wrote:Ah right. Wasn't sure if it was just a speed signal you needed as the pcm has an output for that.
Is this still a secret squirrel wink wink need a password to find oot what this fookin vans for..... Lol.... Ive siigned the osa for work i do for MOD.....give us a clue
ANDZ
andz327
Postby GreaseMonkeyuk » Sun Apr 12, 2020 2:54 pm
ANDZ
Its a 460 and will be used for towing not for personal use more than 60 miles from base so need a tacho
have electrical equipment in the back that needs quite a bit of power when driving on 24 volt system inverter and for starting 24 volt engines so not something that can be done with a split charge plus i would rather not stress the mail alternator
GreaseMonkeyuk
Postby andz327 » Mon Apr 13, 2020 11:46 am
Hahaha is there something you dont want people to know???? We get you need a tacho to tow , i do a bit of towing maself , but what do you actually do , is it plant fitting or marine or what mate or do you really not want to say what it's all about
ANDZ
andz327
