Sender for temperature gauge,
Postby czar » Fri Apr 24, 2020 1:53 am
Hello lads,
I am not mechanically minded ,and I always end up barking my knuckles and banging my head,so excuse me.My old Mk 5 banana is running well but I have noticed that the temperature gauge is barely getting into the 'normal' bracket,it usually sits right in the middle,where can I find the sender? I will give it a twiddle. thanks Les
czar
Re: Sender for temperature gauge,
Postby Heathen » Sat May 23, 2020 5:47 am
I've just bought a similar vehicle, and my temperature gauge is the the same. Even after a lengthy drive (+30 minutes), the gauge barely gets off the lowest reading.
The heater's definitely blowing hot air though, so I doubt it's a thermostat problem.
I have not solved the it yet, but would also appreciate some help.
Heathen
Postby Heathen » Sat May 23, 2020 5:49 am
Whoops. I found your post through a search.
I didn't notice that we're probably in the wrong category to get any quick advice!
Apologies for the clutter, Admin!
Heathen
