2.4 Di Cylinder head Camshaft cage - WANTED
Postby JustaTransit » Fri May 29, 2020 4:21 am
Does anybody have a Cylinder head camshaft cage for a 2.4 Di motor DOFA. That you would like to sell ?
JustaTransit
Re: 2.4 Di Cylinder head Camshaft cage - WANTED
Postby knobby1 » Fri May 29, 2020 5:00 am
JustaTransit wrote:Does anybody have a Cylinder head camshaft cage for a 2.4 Di motor DOFA. That you would like to sell ?
Aren't they matched to the cyl head..??
Postby JustaTransit » Fri May 29, 2020 6:51 am
They can be lapped in to suit the cam journals..... if the cage is too worn then it needs to have material added to the journal area & machined to suit.
JustaTransit
Postby Jim Archer » Fri May 29, 2020 10:41 am
Lapping is only any help if there's a couple of thou' discrepancy. Machining needs the mating face skimmed to give enough meat to centre the top caps with the lower halfs.
May as welll just swap the whole head for the hassle it would save.
Jim
Mk7 140 Jumbo - Vantunered.
289,000 and counting.
Jim Archer
Postby JustaTransit » Fri May 29, 2020 11:28 pm
Okay Thanks for your feedback Jim ... much appreciated.
JustaTransit
Postby karl » Sat May 30, 2020 6:40 pm
ive got a engine with leg out of bed
in manchester £300 for the block and head
karl
Tranny Lover!!!
Postby JustaTransit » Sat May 30, 2020 8:24 pm
Thanks Karl... If I was closer to the UK it would be a done deal. I’m in Queensland Australia.... the freight cost makes it to expensive.... Cheers
JustaTransit
Postby karl » Sun May 31, 2020 12:57 am
JustaTransit wrote:Thanks Karl... If I was closer to the UK it would be a done deal. I’m in Queensland Australia.... the freight cost makes it to expensive.... Cheers
Not many Australians here buddy and these vans are getting rare by the day
karl
Tranny Lover!!!
Postby JustaTransit » Sun May 31, 2020 7:12 am
No worries Thanks mate
JustaTransit
cron
