Ecu unit for a transit van
Postby Tkelly01 » Sun Jul 05, 2020 9:11 pm
Hi there
I am looking for ecu kit which would be engine ecu, keys, ignition barrel pats module for a 2 lt petrol engine fro a transit van on a W reg
I have attached an image of the current unit
I am hoping someone might be able to direct me in the right direction,
Many thanks
Tkelly01
Re: Ecu unit for a transit van
Postby fuzzedup » Thu Jul 16, 2020 10:24 pm
Just bypass the pats system, easy to do
fuzzedup
Postby MinorMatt » Thu Jul 16, 2020 10:48 pm
how do you do that on a petrol?
Lucas Laser 2000 & IDS
93 L GL Minibus
96 P 150 TD 100PS LWB Hi-Top
Postby Tkelly01 » Fri Jul 17, 2020 6:33 am
How do we do that ?
Tkelly01
Postby MinorMatt » Fri Jul 17, 2020 9:19 am
Unless you have an ECU without PATS - you can't AFAIK. I think the person who suggested it thought you have a non turbo diesel.
If you find one, I would strongly suggest you get the associated PATS module and keys, otherwise you may end up with key programming problems!
93 L GL Minibus
