MK5 grill clips
MK5 grill clips
Postby barryorbik » Tue Jul 14, 2020 12:58 pm
Does anyone have four of the oblong plastic clips that the ends of a Smilie grill locate in, or a part number for them.
Tried Google and E Bay but cannot find anything similar on there.
Barry
barryorbik
Re: MK5 grill clips
Postby MinorMatt » Tue Jul 14, 2020 3:22 pm
Oblong plastic clips??
There are 4 plastic "tangs" moulded in to the grille assembly. A metal spring clip fits over these, and it then gets pushed in to the appropriate slots in the front wings
Lucas Laser 2000 & IDS
93 L GL Minibus
96 P 150 TD 100PS LWB Hi-Top
Re: MK5 grill clips
Postby barryorbik » Wed Jul 15, 2020 9:35 am
Thanks for taking the time to reply Matt,
I took my grill off yesterday and it has all of the tangs and metal clips in place, but the ends are very loose fitting, so I assumed it needed plastic inserts in the wing cut outs.
May see if plastic grommet strip helps to take up the slack.
Best regards
Barry
barryorbik
Re: MK5 grill clips
Postby MinorMatt » Thu Jul 16, 2020 3:48 pm
The clips have probably corroded and become less springy...
93 L GL Minibus
