Mk7 RWD MWB Transit TowBar
Postby M4CKK » Wed Aug 12, 2020 4:47 am
Are these easy to fit and wire up?
Any problems I could be made aware about?
Many thanks
Sent from my ONEPLUS A5010 using Tapatalk
GasSafe Registered Installer - Chimneys Swept - Cowls Fitted - Chimney Pots Fitted - Wood Burner Stoves Installed - On-Site Welding
M4CKK
Re: Mk7 RWD MWB Transit TowBar
Postby Noctule » Wed Aug 12, 2020 8:07 pm
Fitting the towbar itself is quite easy.
You'll need a bypass relay to wire up the socket, this takes the load off the relatively small van wiring. Power for this needs to be taken from the customer connection point on the back of the drivers seat. Use 25a cable to reduce voltage drop. The cable to the 12N socket goes through the bottom of the back pillar, there is a rubber bung in there that will need a hole putting in it for the cable to pass through.
There will be a connection point on the bypass relay to run a buzzer or LED repeater in the cab for the indicator telltale.
Solder any connections to the lights loom if you can.
2000 Mk5 HiCube self-build camper
- 2.5di turbo with Bosch conversion
- DRW
- Mondeo instrument cluster
- Lunar Meteorite interior
http://www.hicubecamper.eu
2006 Mk7 115t350 van (cheap tax tramp)
Previously...
Mk5 100 swb Custom
Mk5 190 lwb x3
Noctule
Postby M4CKK » Wed Aug 12, 2020 9:33 pm
Noctule wrote:Fitting the towbar itself is quite easy.
Excellent mate.... Many thanks
M4CKK
Postby M4CKK » Mon Aug 31, 2020 9:56 am
Could you explain why I need a bypass wiring kit?
Could I just wire the 7 wires into the rear lighting circuits?
Many thanks
M4CKK
croncroncron
