MK7 2.2 RWD cooling fan motor wanted
Postby neoxerox » Thu Aug 13, 2020 12:23 pm
Hi All,
I'm after a replacement electric cooling fan motor for my MK7.
I believe it's specific to the 2.2 RWD models with air-con.
Part numbers listed on the removed motor: 5YY0075, 500.0546 (5000546), 3P322108
Thanks, Ben
neoxerox
Re: MK7 2.2 RWD cooling fan motor wanted
Postby Altransit » Thu Aug 13, 2020 4:38 pm
Is it definitely the motor, rather than the fan controller :?:
If it is the motor, and it's seized up, you might be able to remove it, clean and lubricate it :idea:
Just out of interest, is yours a single fan unit, or a double :?:
Postby neoxerox » Mon Aug 24, 2020 12:14 am
Pretty certain as 12v straight to the fan did nothing at all. Any suggestions for other tests?
I have 1x viscous fan & 1x electric fan. I believe this setup is specific to the rwd with Aircon variant.
Sent from my Armor_6S using Tapatalk
neoxerox
