Wanted - 2 Macpherson struts with springs for 1993 petrol Tr
Postby day6steve » Thu Oct 15, 2020 12:36 pm
Need 2 coil springs and 2 struts asap. Also centre propshaft bearing. New or used.
day6steve
Re: Wanted - 2 Macpherson struts with springs for 1993 petro
Postby MinorMatt » Thu Oct 15, 2020 2:03 pm
They aren't McPherson struts... they are just a damper. Mcpherson struts have the spring mounted around the damper and mount the hub.
I have a pair of complete mk4/5 front suspension assemblies (wishbone, knuckle, hub, damper) available on the shelf, removed from a SWB 100 diesel. I have the springs from this too.
Somewhere I also have a new, genuine, propshaft center bearing for a mk4 too - but I may need this for one of my vans (I will have to check what the one on mine is like).
Im in Lechlade in Gloucestershire
Lucas Laser 2000 & IDS
93 L GL Minibus
96 P 150 TD 100PS LWB Hi-Top
croncroncron
