Mk7 2.2fwd Rocker cover
Postby Ellmerfudd » Sun Jan 03, 2021 3:29 pm
Wanted rocker cover to fit MK7 2.2 fwd please, can meet locally (cheshire/staffs) or pay postage cheers
Ellmerfudd
Re: Mk7 2.2fwd Rocker cover
Postby andz327 » Sun Jan 03, 2021 6:07 pm
Have you tried ebayImage
ANDZ
andz327
Postby andz327 » Mon Jan 04, 2021 11:02 pm
Aye, naw, maybe..... Cheers
ANDZ
andz327
Postby Ellmerfudd » Tue Jan 05, 2021 11:52 am
Thank you mate I will take a look now
Ellmerfudd
Postby Stumble » Tue Jan 05, 2021 2:57 pm
Put a new one on, some come with new bolts etc
Believe me its much better than trying to get a used one clean etc
Stumble
Postby andz327 » Tue Jan 05, 2021 5:18 pm
That might be wrong one thats euro 5
Think it would be this one (double check before you buy as breather tube looks at wrong angle so could be rwd )and yes it comes with bolts, injector seals and gasket,(not injector bolts or compression seals)when you think Elring gasket/cover seal is about £18 and individual injector seals for the cover are £8 each then its cheap as some breakers want that for used item Image
ANDZ
andz327
