MK3 power steering
MK3 power steering
Postby Mk3Dave » Mon Feb 22, 2021 9:56 am
I'm looking for a power steering box for my MK3 surrently has one fitted but with a lot of play or even if someone can point me in the direction of a company to refurbish my current one cheers
Mk3Dave
Re: MK3 power steering
Postby dumper » Mon Feb 22, 2021 12:16 pm
On the side of the box is a locknut with I screw slot in it you can screw that in to take some of the play out but don’t over do it as it can make the box stiff .
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
2006 350 jumbo 135 tdci
dumper
Postby Mk3Dave » Mon Feb 22, 2021 7:07 pm
Will give it a try would be nice if it was that simple
Mk3Dave
Postby dumper » Mon Feb 22, 2021 8:39 pm
You cat take for a fair bit out used to do it a lot on mk 1&2 and trucks you are allowed a fair bit of movement on the steering wheel if you get a fail get them to get the manual out and check the spec a lot of car garages and not used to steering box’s and I’ve had them try to fail them on rack and pinion limits
The steering wheel movement is for a 460 mm wheel is maximum of 92 mm of free movement with the engine running.
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
dumper
