Mk3 sliding door catches
Postby auldescort » Fri Jul 30, 2021 11:46 am
Looking for rh and lh sliding door catches for mk3
auldescort
Re: Mk3 sliding door catches
Postby Keef » Sat Jul 31, 2021 1:09 pm
Did they do a MK3 with sliding front doors? I've never seen one if they did or do you mean side loading doors?
Keef
Postby Ralph.9 » Mon Aug 02, 2021 6:41 am
There was a complete MK3 sliding drivers door & fittings on Ebay last week.
Ralph.9
Postby MinorMatt » Mon Aug 02, 2021 8:11 am
which bit do you mean exactly?
Lucas Laser 2000 & IDS
93 L GL Minibus
96 P 150 TD 100PS LWB Hi-Top
Postby auld-escort » Fri Aug 06, 2021 8:42 am
The catch.the part with the spring loaded catch in it. Part numbers on them are
96VB-V264A26-AA
96VB-V264A27-AA
auld-escort
Postby Keef » Sat Aug 07, 2021 11:25 am
I can supply used catches for both sides of sliding side loading doors from a year 2000 Mk5 if you can confirm that's what you need?
Keef
Postby auld-escort » Mon Aug 09, 2021 4:30 pm
no , its mk3 i need
auld-escort
Postby Keef » Mon Aug 09, 2021 7:23 pm
auld-escort wrote:no , its mk3 i need
But the part numbers you've given are for 1996 on hence the 96VB bit at the start of the part number!
Anyway, you know what I've got. Give me a shout if you're interested.
Keef
Postby auld-escort » Tue Aug 10, 2021 8:06 am
ah ok sorry , not too familiar with part numbers. as long as yours have these numbers on them then they should be correct ? or have you a picture of them maybe?
auld-escort
Postby Keef » Tue Aug 10, 2021 9:51 pm
The following pics are with Mk5 on the left and Mk3 on the right of the photo.
It appears that the Mk5 catch is almost identical to the Mk3 catch but apart from an extra metal shroud on the Mk5.
They are certainly interchangeable.
I have both sides of Mk5 version but only left side of Mk3 version
Keef
Postby auld-escort » Thu Aug 12, 2021 9:18 am
thanks for that. how much for a pair of mk5 please
auld-escort
Postby Keef » Sat Aug 14, 2021 5:22 pm
pm sent.
Keef
