MK5 ABS Front hubs & Stub Axles 6-stud twin wheel wanted
MK5 ABS Front hubs wanted
Postby skerr3 » Fri Oct 22, 2021 10:11 am
Hi, I'm trying to source a pair of MK5 front hubs with ABS rotors, does anyone have a pair to sell please?
Steve
skerr3
Re: MK5 ABS Front hubs wanted
Postby MinorMatt » Fri Oct 22, 2021 10:29 am
skerr3 wrote:Hi, I'm trying to source a pair of MK5 front hubs with ABS rotors, does anyone have a pair to sell please?
Steve
5 stud I assume?
Do you need just the hubs or do you need the stub axle too?
The good news is, apart from the ABS ring, the ABS hubs are the same whether ABS or not, the ABS ones just have the ring pressed on. This means if you clean the rust off a non ABS hub you will be able to press the ring on (after cleaning the rust up of course!).
If you need the stub axles, thats slightly different - I may know of someone with a pair though (and I have sensors etc in stock if required)
Lucas Laser 2000 & IDS
93 L GL Minibus
96 P 150 TD 100PS LWB Hi-Top
Postby skerr3 » Fri Oct 29, 2021 3:51 pm
I should have added, 6-stud for a twin wheel set-up.
skerr3
Postby skerr3 » Fri Oct 29, 2021 3:55 pm
Hi, wanted: MK5 ABS Front hubs & Stub Axles 6-stud twin wheel set-up
skerr3
