Mk5 speedometer gear 21 teeth / Mt75
Postby Deas_andre » Tue Jun 14, 2022 7:06 pm
I'm trying to find the speedometer gear for my MT75 gearbox on my Mk5. (I'm not sure if it's also called speedometer pinion?)
It's plastic, 21 teeth. It's the bit which fits inside the gearbox and is driven by the wormgear. I'm not looking for the electronic sensor.
See the link, mine has the shaft broken off it. The other solution would be to make up a replacement shaft somehow, but I'm not sure how to make it sturdy.
https://www.dropbox.com/s/65w1az0ftkdw7 ... 0.jpg?dl=0
https://www.dropbox.com/s/0fe2jkzypq6jt ... 9.jpg?dl=0
'99 Transit, LWB, twin axle, camper
Deas_andre
Re: Mk5 speedometer gear 21 teeth / Mt75
Postby MinorMatt » Wed Jun 15, 2022 4:12 pm
There are several types depending on whether its a cable speedo or electronic & diff ratio etc etc.
Is this for the 1999 one? That should have an electronic speedo? (And yes I appreciate you arn't looking for the sender)
Lucas Laser 2000 & IDS
93 L GL Minibus
96 P 150 TD 100PS LWB Hi-Top
Postby MinorMatt » Wed Jun 15, 2022 4:17 pm
Part number you need is 7321230
I have a yellow one for your application - but the speedo will read wrong
93 L GL Minibus
