Transit tipper body chassis frame
Postby Steveleet » Wed Jan 03, 2024 11:51 am
Looking for a tipper body chassis frame for a 2008 mk7 ford transit.
The tipper body I have is ok but the frame that the tipper body goes onto and then bolts to can chassis is rotten.
Based in Cambridgeshire but can travel.
Steveleet
Re: Transit tipper body chassis frame
Postby Chug » Wed Jan 03, 2024 11:15 pm
I'm not sure if mk5 will fit, I know someone fitted a mk6 tipper body to his mk5 and I believe the mk7 is the same as the mk6?
Anyway I have a mk5 buried in my yard with a tipper on it, it would need a 4wd fork lift to get at it this time of year but I could check what condition it's in at the weekend? But looking at the picture I'm not sure if its as sturdy as yours as its an ali tipper body and not steel.
Chug
Postby Terrymahood » Thu Jan 25, 2024 9:19 pm
Chug wrote:I'm not sure if mk5 will fit, I know someone fitted a mk6 tipper body to his mk5 and I believe the mk7 is the same as the mk6?
How much do you want for the tipper body I would be interested in it for my mk5
Terrymahood
Postby Johnb92 » Sat Mar 08, 2025 8:51 pm
Sorry bit late on the post but I’ve got a tipper body off a 2014 single cab with a tail lift on there also if this is any good
Johnb92
