mk2 ambulance 3litre spares or repair - could go very cheap
Spotted something of interest on eBay or other online auctions, let people know here.
Re: mk2 ambulance 3litre spares or repair - could go very ch
Postby Ralph.9 » Sun Oct 11, 2015 5:50 pm
Yes it was worth it, the transport wasn't to bad as i had a 2nd one to pick up about 5 miles away so i could split the cost between the two.
Ralph.9
Postby MinorMatt » Mon Oct 12, 2015 10:56 am
Its just possible that the axle may also be a limited slip diff version...
Postby Vandalism » Mon Oct 12, 2015 5:25 pm
:shock: £££ 8)
Postby Ralph.9 » Mon Oct 12, 2015 6:29 pm
How would i tell if its LSD?
Ralph.9
Postby walt1984 » Mon Oct 12, 2015 6:43 pm
If its a running, jack the back end so one wheel is off the ground then try and drive it. If its lsd it will try and drive off the jack, if not the wheel off the ground will spin.
If its a non running raise booth wheels and turn one by hand. I think with lsd the opposite site wheel will turn same direction non lsd will be reversed.
"due to ever increasing work load the light at the end of the tunnel has been turned off!"
walt1984
Postby MinorMatt » Mon Oct 12, 2015 7:17 pm
Jack both rear wheels up... in gear you won't be able to turn them, out of gear they will rotate in the same direction.
If its open you turn one wheel, the other will rotate in the opposite direction
Return to eBay/ Auction Ads
