Respray with minimum masking?!!
Spotted something of interest on eBay or other online auctions, let people know here.
Postby Keef » Wed Apr 20, 2016 9:52 am
Keef
Re: Respray with minimum masking?!!
Postby davew2 » Wed Apr 20, 2016 10:37 am
Its going to look bad when the paint starts flaking of the trim :roll:
If it ain't got leaf springs it in't a commercial
davew2
Postby Dodge20 » Wed Apr 20, 2016 11:06 am
I was quite surprised that the interior wasn't red as well :lol: .
Some people are like slinkies.... not good for much but bring a smile to your face when you push them downstairs.
2009 280 85hp
2015 290 Custom DCIV twin side doors 155hp(tragically killed)
Dodge20
Location: Go to the end of the world and turn left. (South Cumbria)
Postby boltondigger » Wed Apr 20, 2016 7:33 pm
Nowt wrong with a bit of Dulux gloss :lol: :lol: :lol:
Had a rusty old 58 plate 85 ps swb.180 thou .most reliable bus ive ever had
12 plate limited 125bhp 260 that got nicked :shock: :shock:
2016 connect poverty spec
boltondigger
Postby transitandy » Thu Apr 21, 2016 1:39 pm
Dodge20 wrote:I was quite surprised that the interior wasn't red as well :lol: .
Well yeah :lol: :lol:
Postby acarpen9 » Mon Apr 25, 2016 11:36 am
I love how the passenger wing mirror casing is missing and they've just painted the inner :lol:
If it has four legs and is not a chair, has wings and is not an aeroplane, or swims and is not a submarine the Cantonese will eat it
acarpen9
Postby MinorMatt » Mon Apr 25, 2016 4:49 pm
Honestly... you lot must be living in the dark ages...
Its called colour coding!
Postby screechowl » Mon May 02, 2016 1:01 am
What a mess :shock:
screechowl
Postby blue estate » Mon May 02, 2016 9:04 am
Registration number: W782HES
Vehicle make: FORD
Vehicle model: TRANSIT
Date first used: 1 March 2000
Fuel type: Diesel
Colour: Red
MOT history of this vehicle
Test date: 7 April 2016
Expiry date: 6 April 2017
Test Result: Pass
Odometer reading: 132,444 miles
MOT test number: 6653 1304 6172
Test date: 1 April 2016
Test Result: Fail
Odometer reading: 132,439 miles
MOT test number: 9473 9782 0964
Reason(s) for failure:
Parking brake: efficiency below requirements (3.7.B.7)
Windscreen washer provides insufficient washer liquid (8.2.3)
Registration plate lamp does not illuminate simultaneously with the position lamps (1.1.C.1a)
nearside rear Vehicle structure has excessive corrosion, seriously affecting its strength within 30cm of the body mountings (6.1.B.2)
offside rear Vehicle structure has excessive corrosion which adversely affects braking or steering (6.1.A.1)
centre front Vehicle structure is damaged, seriously affecting its strength within 30cm of the body mountings (6.1.B.2)
Test date: 5 November 2014
Expiry date: 7 November 2015
Test Result: Pass
Odometer reading: 128,854 miles
MOT test number: 1094 2960 4335
Advisory notice item(s):
Vehicle structure has slight corrosion (6.1.A.1)
Test date: 7 November 2013
Expiry date: 7 November 2014
Test Result: Pass
Odometer reading: 125,087 miles
MOT test number: 1559 5111 3355
Offside Rear Body has slight corrosion (6.1.B.2)
Nearside Rear Body has slight corrosion (6.1.B.2)
Offside Body has slight corrosion (6.1.B.2)
Front Body has slight corrosion (6.1.B.2)
Service brake: service brake efficiency only just met. It would appear that the braking system requires adjustment or repair. (3.7.B.7)
Non obligatory mirror damaged
Test date: 8 November 2012
Expiry date: 7 November 2013
Test Result: Pass
Odometer reading: 121,678 miles
MOT test number: 2679 3321 2359
head lights poor image
underside sills floor and chassis weak and corroding
front exhaust slight blow and corroding
front anti roll bar bushes wearing
Test date: 7 November 2012
Test Result: Fail
MOT test number: 2151 6251 2300
Horn not working (1.6.2a)
Offside Front position lamp(s) not working (1.1.A.3b)
Offside Front Tyre has ply or cords exposed (4.1.D.1b)
Offside Front Suspension component mounting prescribed area is excessively corroded (2.4.A.3)
Offside Rear Suspension component mounting prescribed area is excessively corroded (2.4.A.3)
Rear Exhaust has a major leak of exhaust gases (7.1.2)
Rear Exhaust system not adequately supported (7.1.1)
Nearside Headlamp aim too high (1.8)
Offside Headlamp aim too high (1.8)
Test date: 6 October 2011
Expiry date: 1 November 2012
Test Result: Pass
Odometer reading: 117,765 miles
MOT test number: 9596 9927 1276
underside corroding ;front anti roll bar bushes wearing ;front discs corroding
Test date: 26 September 2011
Test Result: Fail
Odometer reading: 117,764 miles
MOT test number: 3184 8906 1484
Registration plate lamp not working (1.1.C.1d)
Nearside Front Suspension component mounting prescribed area is excessively corroded (2.4.A.3)
Nearside Rear Suspension component mounting prescribed area is excessively corroded (2.4.A.3)
Rear Service brake: service brake efficiency only just met. It would appear that the braking system requires adjustment or repair. (3.7.B.7)
Test date: 2 November 2010
Expiry date: 1 November 2011
Test Result: Pass
Odometer reading: 114,520 miles
MOT test number: 9600 0630 0367
Windscreen has damage to an area less than a 10mm circle within zone 'A' (8.3.1a)
Nearside Rear Tyre worn close to the legal limit (4.1.E.1)
Offside Rear Tyre worn close to the legal limit (4.1.E.1)
Nearside Front Tyre worn close to the legal limit (4.1.E.1)
Nearside Front wheel bearing has slight play (2.5.A.3c)
Offside Front wheel bearing has slight play (2.5.A.3c)
front discs pitted
Test date: 29 October 2010
Test Result: Fail
Odometer reading: 114,489 miles
MOT test number: 4830 0220 0386
Nearside Obligatory mirror missing (8.1.1)
Nearside Rear Suspension spring mounting prescribed area is excessively corroded (2.4.A.3)
Offside Rear Suspension spring mounting prescribed area is excessively corroded (2.4.A.3)
front discs pitted
Test date: 29 October 2009
Test Result: Fail
Odometer reading: 107,697 miles
MOT test number: 1212 2290 9354
Nearside Headlamp aim too high and too far to the right. (1.8)
Nearside Registration plate lamp not working (1.1.5c)
Offside Registration plate lamp not working (1.1.5c)
front wheelarches corroded
Expiry date: 28 October 2010
Test Result: Pass
MOT test number: 2622 1230 9359
Test date: 13 October 2008
Expiry date: 12 October 2009
Test Result: Pass
Odometer reading: 102,084 miles
MOT test number: 3704 7708 8217
Test date: 14 September 2007
Expiry date: 17 September 2008
Test Result: Pass
Odometer reading: 95,457 miles
MOT test number: 3046 8755 7458
Test date: 18 September 2006
Expiry date: 17 September 2007
Test Result: Pass
Odometer reading: 87,945 miles
MOT test number: 7304 4106 6252
Test date: 16 August 2006
Test Result: Fail
MOT test number: 9746 4882 6244
Nearside Front position lamp(s) not working (1.1.A.3b)
Offside Rear Registration plate lamp not working (1.1.5c)
Offside Front Anti-roll bar linkage fractured (2.4.G.1)
Nearside Front Anti-roll bar linkage rubber bush bonding deteriorated resulting in excessive movement (2.4.G.2)
Nearside Front Windscreen wiper blade deteriorated (8.2.2)
Offside Front Windscreen wiper blade deteriorated (8.2.2)
Brake cable has restricted free movement (3.5.1k)
Search again
Cookies
Terms and Conditions
Open Government Licence
All content is available under the Open Government Licence v2.0, except where otherwise stated
blue estate
Postby Vandalism » Tue May 03, 2016 11:32 am
http://www.ebay.co.uk/itm/FORD-TRANSIT- ... SwKfVXGi~Y
this ones similar, just sprayed over without repairing the areas 8)
Postby stevo » Tue May 03, 2016 3:16 pm
What a shed
Sent from my HTC One_M8 using Tapatalk
Formely ibanez2005
Your's is the new Ford Transit!
2003 100 T260 TDDi swb
stevo
Postby stevo » Tue May 03, 2016 3:19 pm
Vandalism wrote:http://www.ebay.co.uk/itm/FORD-TRANSIT-110-2-OWNERS-FROM-NEW-ONLY-104K-MILES-READY-FOR-WORK-OR-PLAY-/331834816865?hash=item4d42e57961:g:0PsAAOSwKfVXGi~Y
He's dreaming with that price for that. Id rather be able to see the rust instead of them covering it up and trying to fool people.
Formely ibanez2005
stevo
Postby davew2 » Tue May 03, 2016 7:19 pm
seems to be a bit of a theme going here but at £7000 i would expect better :roll:http://www.ebay.co.uk/itm/ford-transit- ... SwY3RXJgfN
davew2
Postby Vandalism » Wed May 04, 2016 11:17 am
camper vans seem to hold their money despite being right old bodged up...look at prices for the talbot ones for instant...surly a transit is better than one of thos :lol:
Postby stevo » Wed May 04, 2016 5:54 pm
davew2 wrote:seems to be a bit of a theme going here but at £7000 i would expect better :roll:http://www.ebay.co.uk/itm/ford-transit- ... c2b15400:goYAAOSwY3RXJgfN
At least that one is nicely kitted out inside, from those pictures it looks pretty decent. Still wouldnt pay that for it though.
Formely ibanez2005
stevo
Return to eBay/ Auction Ads
