2001 ford transit campervan turbo diesel 52.000
Spotted something of interest on eBay or other online auctions, let people know here.
Postby screechowl » Sat Apr 30, 2016 11:30 pm
https://scontent-lhr3-1.xx.fbcdn.net/hp ... e=579EC19D
Can be found on the 'Campervans' Facebook group...
screechowl
Re: 2001 ford transit campervan turbo diesel 52.000
Postby transitandy » Sun May 01, 2016 12:15 am
A lovely late mk5 8) 8) 8)
Looks very clean and only 52000 miles :)
Postby screechowl » Sun May 01, 2016 8:00 pm
Look at the previous advisories on the MOT check site tho :?
And doesn't exist on the Etis site....
screechowl
Postby blue estate » Sun May 01, 2016 8:03 pm
screechowl wrote:Look at the previous advisories on the MOT check site tho :?
Registration number: HX51NNL
Vehicle make: FORD
Vehicle model: TRANSIT
Date first used: 9 October 2001
Fuel type: Diesel
Colour: White
MOT history of this vehicle
Test date: 3 November 2015
Expiry date: 11 November 2016
Test Result: Pass
Odometer reading: 50,673 miles
MOT test number: 3717 6142 2001
Advisory notice item(s):
offside front Suspension component mounting prescribed area is corroded but not considered excessive inner flitch (2.4.A.3)
offside rear Suspension component mounting prescribed area is corroded but not considered excessive chassis rail (2.4.A.3)
Suspension component mounting prescribed area is corroded but not considered excessive rear cross member (2.4.A.3)
nearside rear Suspension component mounting prescribed area is corroded but not considered excessive chassis rail / inner flitch (2.4.A.3)
Test date: 28 October 2015
Test Result: Fail
Odometer reading: 50,574 miles
MOT test number: 7353 1975 4516
Reason(s) for failure:
Exhaust has a major leak of exhaust gases front section (7.1.2)
Suspension component mounting prescribed area is excessively corroded both centre / rear chassis rail outriggers (2.4.A.3)
nearside rear Suspension component mounting prescribed area is excessively corroded cross member (2.4.A.3)
nearside rear Suspension component mounting prescribed area is excessively corroded under sill panel (2.4.A.3)
offside rear Suspension component mounting prescribed area is excessively corroded chassis rail / inner flitch (2.4.A.3)
Test date: 17 October 2014
Expiry date: 11 November 2015
Test Result: Pass
Odometer reading: 47,584 miles
MOT test number: 8579 7049 4221
Front Exhaust has a minor leak of exhaust gases (7.1.2)
Test date: 16 October 2013
Expiry date: 11 November 2014
Test Result: Pass
Odometer reading: 41,607 miles
MOT test number: 3875 1988 3439
Test date: 11 November 2012
Expiry date: 11 November 2013
Test Result: Pass
Odometer reading: 36,678 miles
MOT test number: 6058 3641 2399
Rear registration plate deteriorated but not likely to be misread (6.3.1d)
Brake hose has slight corrosion to ferrules (3.6.B.4e)
front brake discs scored
offside front tyre worn inner edge
white furring on brake pipes
Test date: 27 October 2011
Expiry date: 11 November 2012
Test Result: Pass
Odometer reading: 31,403 miles
MOT test number: 8052 9080 1384
Test date: 12 November 2010
Expiry date: 11 November 2011
Test Result: Pass
Odometer reading: 27,507 miles
MOT test number: 7449 6681 0331
Test date: 14 December 2009
Expiry date: 13 December 2010
Test Result: Pass
Odometer reading: 27,392 miles
MOT test number: 8836 1884 9375
vehcile tested as class 4 motor caravan dgw 3850kg
Search again
blue estate
Postby bigjohnthomas » Sun May 01, 2016 8:08 pm
don't worry about the reg not coming up on etis screch quite a few don't for vairarse reasons
now tell me
in minute detail
what are you wearing?
helpful??
thanks !!!!!!
allcock the vicar
bigjohnthomas
Postby screechowl » Sun May 01, 2016 8:33 pm
That list just reminds me of my old Rusty Green...
I personally think the the interior is too modern & standardised for a mk5 if it was more funky & recycled & a lot cheaper I might have bought it.
Ok I wont worry if they don't show on Etis but what reasons?
(Not a lot)
screechowl
Postby bigjohnthomas » Sun May 01, 2016 8:42 pm
Irish import ..
and mine for instance was registered from new on a private plate so that doesn't come up unless you put the reg number that's now on a Citroen in
you need the vin number if the reg doesn't come up
I have piss stained pantaloons and a Alvin the chipmonk tshirt on wink
bigjohnthomas
Postby transitandy » Sun May 01, 2016 10:28 pm
Someone who can weld would have a lovely transit for sure :)
Return to eBay/ Auction Ads
