Anyone looking for a near mint swb MK5?........
Spotted something of interest on eBay or other online auctions, let people know here.
Postby pelmetman » Mon Aug 29, 2016 6:07 pm
Fanny a 99 LWB Semi high roof MK 5......Essex V6 auto..... Sold
Horace a 90 SWB Ford Travelhome MK 3....2.5 diesel manual
pelmetman
Re: Anyone looking for a near mint swb MK5?........
Postby dumptruck » Mon Aug 29, 2016 7:04 pm
It looks like it's just came out of the spray booth!
Is it an ex BT van?
dumptruck
Postby blue estate » Mon Aug 29, 2016 7:12 pm
dumptruck wrote:It looks like it's just came out of the spray booth!
Is it an ex BT van?
Had new wheel arch
Registration number: R572UOC
Vehicle makeFORD Vehicle modelTRANSIT Date first used24 March 1998 Fuel typeDiesel ColourGrey
MOT history of this vehicle
Test date26 August 2016 Expiry date25 August 2017 Test ResultPass Odometer reading54,753 miles MOT test number8279 3824 2726
Test date28 May 2015 Expiry date27 May 2016 Test ResultPass Odometer reading53,696 miles MOT test number1291 9804 5140
Test date27 May 2015 Test ResultFail Odometer reading53,693 miles MOT test number4997 1784 5190 Reason(s) for failure
Nearside Headlamp excessively deteriorated so that the light output is severely reduced (1.7.5a)
Offside Headlamp excessively deteriorated so that the light output is severely reduced (1.7.5a)
Offside Windscreen wiper does not clear the windscreen effectively (8.2.2)
Rear registration plate deteriorated (6.3.1d)
Test date4 April 2014 Expiry date3 April 2015 Test ResultPass Odometer reading52,377 miles MOT test number9797 8409 4056 Advisory notice item(s)
Offside Headlamp deteriorated but light output not reduced (1.7.5a)
Test date2 April 2012 Expiry date1 April 2013 Test ResultPass Odometer reading51,875 miles MOT test number4757 6359 2066 Advisory notice item(s)
Body has slight corrosion (6.1.B.2)
clutch pedal anti-slip missing
Test date1 April 2011 Expiry date31 March 2012 Test ResultPass Odometer reading50,416 miles MOT test number2656 2159 1009 Advisory notice item(s)
Nearside Front Shock absorber has a light misting of oil (2.7.3)
off side rear tyre very badly perrished
near side rear wheel arch corroded
Test date1 April 2011 Test ResultFail Odometer reading50,416 miles MOT test number5869 2119 1055 Reason(s) for failure
Nearside Windscreen wiper does not clear the windscreen effectively (8.2.2)
Test date9 April 2009 Expiry date8 April 2010 Test ResultPass Odometer reading40,890 miles MOT test number1303 8999 9067 Advisory notice item(s)
Nearside Front Brake hose slightly deteriorated (3.6.B.4d)
Offside Front Brake hose slightly deteriorated (3.6.B.4d)
Brakes imbalanced requirements only just met. It would appear that the braking system requires adjustment or repair. (3.7.B.5b)
clutch pedal rubber missing
Test date4 April 2008 Expiry date3 April 2009 Test ResultPass Odometer reading45,734 miles MOT test number1242 5529 8084 Advisory notice item(s)
cuts in off side rear tyre
Test date26 March 2007 Expiry date25 March 2008 Test ResultPass Odometer reading42,064 miles MOT test number2118 8548 7073
Test date26 March 2007 Test ResultFail Odometer reading42,064 miles MOT test number9846 8528 7010 Reason(s) for failure
Nearside Front Headlamp aim too low (1.8)
Offside Front Headlamp aim too low (1.8)
Brake pedal anti-slip provision missing (3.3.A.1b)
Offside Front Tyre tread depth below requirements of 1.6mm (4.1.E.1)
Search again
blue estate
Postby ake » Mon Aug 29, 2016 7:44 pm
That looks good, but what is the fresh paint hiding?
Postby pelmetman » Mon Aug 29, 2016 7:54 pm
Is it an ex BT van?
Had new wheel arch
Search again
For a MK5 that lot is near mint :mrgreen: ......
pelmetman
Postby transitandy » Tue Aug 30, 2016 9:09 pm
Making good money.
Postby derv23 » Tue Aug 30, 2016 9:55 pm
Does look nice.
What's up with the back door though, not closed properly or a bit squint ?!
MK5 Tourneo.
derv23
Return to eBay/ Auction Ads
