What's this?
Spotted something of interest on eBay or other online auctions, let people know here.
What's this?
Postby Jim H » Sun Mar 08, 2020 7:48 pm
Plodding along.
Jim H
Re: What's this?
Postby yzr750 » Mon Mar 09, 2020 6:15 am
A Ford Transit?
yzr750
Re: What's this?
Postby Jim H » Mon Mar 09, 2020 11:51 am
How positively droll! :D
I ment is it a Mk1 With a hell of a lot of Mk2 bits thrown at it or a Mk2 with a Mk1 front end? . . . .
Plodding along.
Jim H
Re: What's this?
Postby dumper » Mon Mar 09, 2020 1:28 pm
It looks like the early mk1 York engine that was fitted in a mk 1 on the right of the engine bay you can see the motor unit that puts the fuel cold start on the Lucas Minniemeck fuel pump saves you opening the bonnet to push the button in manually it has also has the little fuel reservoir for the flame start plug in the inlet manifold.
I think if it was a York engine out of a mk2 it would have the 4 glow plug in the cylinder head system back in the day at work I fitted two Ford exchange engines in two mk 1 vans when the mk2 was on the road and they came with the later cold start system you got the full electric system to convert to the automatic cold start and you removed all the old system I think the engines even came with the later Bosch pump and electric stop .
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
2006 350 jumbo 135 tdci
dumper
Re: What's this?
Postby dumper » Mon Mar 09, 2020 5:02 pm
dumper wrote:It looks like the early mk1 York engine that was fitted in a mk 1 on the right of the engine bay you can see the motor unit that puts the fuel cold start on the Lucas Minniemeck fuel pump saves you opening the bonnet to push the button in manually it has also has the little fuel reservoir for the flame start plug in the inlet manifold.
Just thinking I got it wrong the motor unit on the left is actually the stop control the overload was put on with a solenoid the same type as used to engage the overdrive on some gearboxes from some BMC models
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
dumper
Re: What's this?
Postby Adam mk1 » Mon Mar 09, 2020 9:12 pm
It's a mk2 rebuilt from mk1 bits, mk2 was probably a coach built camper (hole in back of cab) they probably already had a rusty mk1 bought the mk2 and made one up out of the pair, no one is ever going to spot the mk2 dash
Adam mk1
Location: Live in southsea Portsmouth, work nr Winchester
Return to eBay/ Auction Ads
