by MinorMatt » Wed Jan 29, 2014 6:20 pm
Mk4 and mk5 (which is what you have) 5 stud axles (which is what I am assuming you have) came with 5.14, 4.56 and 4.11 ratios. Which can be interchanged at will.
Earlier ones also came with 3.9 and 3.7 diff (which are very rare). These are not a direct fit, but all you need to do is change the differential center (the bit the halfshafts go in) to the later mk4/5 one.
The smaller the number on the differential, the more it will drop the revs for a given speed.
