Air horn wiring??
Air horn wiring??
Postby trannydenz » Thu Jul 16, 2015 7:01 pm
Got 2 air horns to go on Mk6 skip truck one for either sides of the roof, each horn has its own little compressor, will I need to wire in a relay and fuses being as there is two compressors to power or can I just tap into the existing horn by dismantling the steering wheel, I'm thinking to tap into horn being as it will only be used In short blasts, thought I'd ask before I do it so I don't turn my truck into a barbecue
trannydenz
Re: Air horn wiring??
Postby g-man » Thu Jul 16, 2015 7:12 pm
no wiring diagram?......would think it needs a relay
g-man
Postby kalkat » Thu Jul 16, 2015 9:29 pm
Use relays ... one for each compressor.
.......... hitting things since I was old enough to hold a hammer
kalkat
Location: Wodering if everything in the farm building has rusted solid yet?
Postby trannydenz » Thu Jul 16, 2015 10:18 pm
Thanks, Wouldn't one relay do the same job if I was to join the wires together from the compressors and then fit the relay after the join
trannydenz
Postby whitemice » Thu Jul 16, 2015 11:15 pm
Wire the relay onto the connector at the original horn is what's easiest.
https://www.youtube.com/watch?v=jIaGWURONRU
'' VOTE Kim Jong Unwell.
Mike writ '' a vote for lABOUR is a vote for islam and a conservative vote is a vote for islam and a vote for liberal is a vote for islam. ''
DBVM ''a vote for UKIP is a vote for islam''
whitemice
Location: normalised heavily chemtrailed cretinous individual just like you
Postby TIMO » Thu Jul 16, 2015 11:33 pm
whitemice wrote:Wire the relay onto the connector at the original horn is what's easiest.
I wired my single compressor airhorn to the original horn wires without a relay,,, am i going to hell ?
BBC = British Broadcasting Conspiracy
http://www.youtube.com/watch?v=nj82wxnO ... r_embedded
TIMO
Postby whitemice » Fri Jul 17, 2015 12:14 am
STUCK A S/S BOAT ONE ON MINE AND I'M ALREADY IN HELL MAN, what is a relay then? :lol: :lol: :lol:
two little compressors will only need a 20 or 30amp one if they exist?
whitemice
Postby loot » Fri Jul 17, 2015 5:15 pm
The small mk7 relays are 20A :-)
You could use a slightly larger mk6/standard relay, i bet it'll be 30A.
you can use 1 on both motors it's highly unlikely that you'll power them for any length of time other than toot toot unless you are horn crazy? In which case you deserve to go to hell shhh there's kids in bed :?
:lol:
07 350 170ps
Ids map here
loot
Postby trannydenz » Sat Jul 18, 2015 9:22 pm
Tested them on the battery and they're bloody LOUD , so decided to wire them to separate switch on dash using 30 amp relay and Inline fuse and picked up the live from fag lighter, also fitted vision alert led lightbar, thanks for the advice :D
trannydenz
Postby whitemice » Sat Jul 18, 2015 9:25 pm
Looks cool matey 8)
whitemice
Postby robbie.cee » Wed Jul 22, 2015 10:08 pm
Mate those compressors dim headlamps they pull so Much power ypu wanna.feed em battery to relay to compressors with thick wire rather than pulling power from fag lighter!
Had
X-Reg Mk5 150ps 3.0 ESSEX V6
MAKE IT FIT
robbie.cee
