Bulkhead removal
Bulkhead removal
Postby suet » Fri Oct 30, 2020 12:09 pm
Hi
I am looking at buying either a ford transit custom sport 320S SWB or 320L LWB DCiV
It seems possible to remove the bulkhead in the LWB but does anyone know if the bulkhead can be removed in the SWB please? Mixed comments from Ford dealers - one said yes, one said no as it contains part of the curtain air bag
any clarification appreciated
thanks
suet
Re: Bulkhead removal
Postby longhair » Fri Oct 30, 2020 8:23 pm
Yes it comes out easy. Just remove the bolts at the top, bottom and sides and out it comes.
longhair
Postby longhair » Fri Oct 30, 2020 8:33 pm
Forgot to mention it comes away in Two pieces. Obviously you remove the top first then the bottom. :D
longhair
Postby suet » Fri Oct 30, 2020 11:25 pm
thank you for your reply - i assume your referring to the dual cab right? Do you know if the one in the SWB comes off easy also and no interaction with air bags?
cheers
Sue
longhair wrote:Forgot to mention it comes away in Two pieces. Obviously you remove the top first then the bottom. :D
suet
Postby longhair » Sat Oct 31, 2020 12:05 pm
No, sorry I'm referring to the single cab. I misread your original question. I couldn't tell you about the dciv. Have you tried the search function or maybe YouTube.
longhair
croncroncron
