****NOW BOOKED FOR 2022**** Transitmania 13 @Santa Pod 20th 22nd May 2022 ****ALL DETAILS HERE****
modifying the atlas axle
Re: modifying the atlas axle
Postby Chug » Tue Jan 11, 2022 12:19 am
Good to see you are making progress too :mrgreen:
will the old holes in the hub get welded up or just left?
what size tube you looking for in case I come across any?
Chug
Postby BROWNYS V6 » Tue Jan 11, 2022 7:59 pm
cheers mate, old holes will be gone as were going to turn the hub down eventually, will need to pull the van apart to measure the inside of the rear discs(merc vito :wink: ) then we can turn them down, the tube i need is 73mm od and 58mm id with an 8mm or 10mm wall thickness and we should be able to machine it to marry the 2 together (i think) :lol:
cheers :)
BROWNYS V6
Postby BROWNYS V6 » Tue Jan 25, 2022 9:47 pm
Test
BROWNYS V6
cron
