stugg77 wrote:Any more updates for this build?
paul2012 wrote:tony&kasia wrote:A big thank you to paul2012 who has posted some great info with his project including wiring details for the screen & hazzard switches etcPaul2012 is going to do our mk7 front end conversion
So we are really happy about that
No problem m8![]()
I will be posting wiring details for column switchgear at some point over the weekend
tony&kasia wrote:Ok some updates as not really had any time to do much due to work & family life. I have took pictures & will post soon. But I have got the dash board in & have everything mk7 fitted. I fitted a c max steering wheel & looks good. I still got a bit of wiring left to do but upon checking what I have done so far the front & rear screen switches work that I got from a c max. The indicators work with the mK7 stalk. The horn works & airbag is connected. The mk7 key reader works as the engine starts. The modified hazard switch works. Just got front & rear wipers to do & the high low beam flashers. So all good.
The ducting was a pain because I had to modify the one behind the glove box again because the glove box would not close.![]()
The only problem at the moment is my speedo is jumping up to 20mph when I start the engine. Could that be down to the battery as I always have to jump start it? It done the same with the old clocks so I know it's not the clocks.
Next job is to get the tailgate fitted & the back straightened out. I did fit the new carpet arches when dash was out. I nearly forgot![]()
Not fitted gear cables yet. Hope to do that the weekend
