so could some bright spark (no pun intended) please confirm if this is correct or point out any faults? thanks in advance.
the fuse should go between the battery and the relay not the relay and the lights as shown
the live wire from battery to relay should be connected to pin number 30
the earth from battery to relay is pin number 86
the live wires from lights to relay is pin 87
and the final wire runs from switch to relay pin 85
